3M TriZact Belt "grits"??????
Can someone translate the "A" listings on the Trizact belts to plain english grit sizes?
TIA
Dave Evans
Tenino, WA
Proud Member
Buck Collector's Club
American Knife and Tool Institute
Oregon Knife Collectors Association
UsedKnife.Com
Hmm, this is just off the top of my head, but here goes:
A65-> 240/280 grit
A45-> 400 grit
A30-> 600 grit
A16-> 1000 grit
A6-> 2000 grit
BTW, is it just me or do these not seem to stay 'fresh' very long when you use em on 3V?
Rich
A100=180 grit
A65=240 grit
A45=320 grit
A30=400 grit
A16=900 grit
A6=1800 grit
Right out of the catalog.
C.O.'s-"It takes balls to work behind the walls "
3V eats Trizact belts in a hurry. It will go from fresh belt to used up in one blade in my experience.
On the grit equivalents, I've seen three different ratings now. Both the above are in the ballpark, IMO.
Jerry Hossom
www.hossom.com
The Tom & Jerry Show
Win,
Sorry, I should have stated that the conversion came from the Bader catalog. Bader is usally pretty informative about things, so I would venture to say that this is accurate.
the trizact belts to me seem not to last long period. not a good value for their high cost. i prefer the ceramics. life became a grind, so i bought a grinder. laurence segal RHINOKNIVES.com
I got them in A165. What's that for a grit size?
Rhinoknives, you have to use a soft backup for those belts. If you use them on a plain steel grinding plate, they won't last long and won't grind well. I got this information from the technical support of my 3M dealer.
Achim
One thing that I may add. They will burn micarta like nobody's business (I had to try) unless you slow your grinder waaaaaaaaay down.
They work extremely well with steel, not so good with any handle material that I have found.
[This message has been edited by C L Wilkins (edited 08-12-2000).]
