I did toe to toe edge retention battle against
E
EatingSarma
today.
We cut some carpet, I used 3V Mini Pendleton, and he had that D2 Boker Gobag.
We used same portion of the blade.
12 cuts and my knife would no longer cut paper while it took 16 cuts for his blade to no longer cut paper.
Mini Pendleton is thinner behind the edge than Gobag, and is also bit thinner overall, meaning it should have the advantage.
So I had EatingSarma sharpen both blades back to shaving sharp again (he is bit better at sharpening highly wear resistant steels than I am).
Results after sharpening are next:
3V: 14 cuts
D2: 19 cuts
Is 3V supposed to be less wear resistant than D2? Would 3V do better on some other test medium?
I'm just hoping that this doesn't mean heat treat is bad.
3V: 14 cuts
D2: 19 cuts
