I do understand your frustration. I own several BRKs, and I'm here to tell you that your 4.1 will far exceed anything out of the BRK shop for functionality. But for those on a budget and in need of a knife to use, S! in the current state is probably not the way to go. BRK makes very good knives, and you would be better served by a Bravo 1 than by nothing in a 4 inch fixed blade category for the past year.
Under the current circumstances, S! Is not the knife maker for everyone. But it will not be too much longer before the 4.1s will be shipping out the door. If you need something to tie you over, pick up something used off the exchange at a reasonable price. When you compare it to the 4.1 once received, I'm confident that you will agree that the wait was worth it.
Thanks for sharing your thoughts, I guess I came across as more negative than meant to.
You make some good points and I think it's easy for those who collect knives to say just use something else while you wait.
I don't have a lot of money to spend on knives these days, like so many of us after buying my fair share of cheap/crappy knives I've learnt it's better to save up and buy quality that will last, hence ordering the 4.1.
Current camping/outdoor tasks are handled with a Mora and a BK9, so I'm covered but at the same time there is definitely need for a quality 4" blade.
BTW just for fun I went back and compiled the list of 4.1 notes from the monthly updates, so we can all remind ourselves that despite the delays there is a steady march of progress.
8-15- We also have GSO-4.1 steel. Cutting is scheduled for late August.
9-15- Next up for the water jet cutting will be the GSO-4.1
10-15- Water jet cutting will start on the GSO-4.1 this month.
11-15- There were a lot of GSO-4.1 orders placed in the last few days of the preordering being open. We need more steel for this run and will start cutting blades as soon as those extra sheets arrive.
12-15- The GSO-4.1 run is getting cut out and machined to size.
1-16- GSO-4.1 blanks are going to production grinding later this month.
2-16- The GSO-4.1 blanks are heading to production grinding.
3-16- GSO-4.1 blanks are at production grinding.
4-16- GSO-4.1 blades will be moving to heat treat this month.
5-16- GSO-4.1 blades are finishing up at heat treating.
6-16- GSO-4.1 blades are mostly done at heat treat. Sheaths are being pressed!
7-16- GSO-4.1 blades are all at the SURVIVE! workshop. Other materials are being completed over the next few weeks.
So apart from Nov-15 it's been pretty solid forward progress, which has oddly cheered me up a little.
T.
