Does anyone have a 416 stainless heat treat recipe that they might want to share? I have some custom pivot barrels I need to make.
Download this app: asm international heat treaters guide companion. According to it you can harden by heading to 1695 to 1850 and quenching in oil, temper at 400-1400. 42HRC as quenched. Ht is far more complex than just this though, check out the app.
For guards and integral liners (for slipjoints) I put 416 (in stainless foil) in the oven at 1900 for 30 min, then temper at 1100 for 2 hours. This produces around 32-33rc. It machines and works beautifully at low to mid 30’s
I had never thought about HT'ing 416 SS for guard use. I guess that helps keep it from scratching so easily in use?
Probably doesn’t help all that much on scratches, but I do it primarily because it works so nice in a hardened state.
So, would you heat treat the pivot pin on a slip joint? I am guessing not, but can't find it explicitly said either way...
