- Apr 10, 2013
Hello all ...!
I am a Rookie Knives Builder, I build generally big knife with stainless 440C with 1/4 inch thickness. I built a forge propane that works very well ...
http://youtu.be/9lYqDM_9Uj8
Q: How do you heat treatment for hardening stainless 440C ...!
I read MANY FORUM, lots of info on many site, sometimes there much difference between the treatment recommended by the manufacturer of metal and those of Knives Builder.
Usually, on the sites of 440C stainless producer, they recommend always the following treatment:
1. To anneal 440C stainless steel, heat uniformly to 840-875°C. Soak and cool very slowly in the furnace.
2. To harden stainless steel 440C heat to 1010-1070°C, fully soak and quench in warm oil or air cool. Be careful not to overheat or full hardness will not be obtained.
3. When tempering 440C a Rockwell hardness of 60HRc can be obtained. Temper for at least one hour. Tempering above 400°C is not recommended as this can cause a reduction in corrosion resistance and impact properties.
Some References:
http://www.westyorkssteel.com/stainless-steel/martensitic/440c/
http://cartech.ides.com/datasheet.aspx?i=103&e=72
http://www.beartechalloys.com/440-stainless-steel.html
http://www.interlloy.com.au/data_sheets/stainless_steel/440c.html
Personally I use the method recommended by the manufacturer. however, several knivemakers have very particular method, may be it is based on the thickness and size of the blade ?
what do you think..?
What is your surefire recipe for tempering 440C..?
thank you.
excuse the quality of my English, I speak French ... and Google translate
Some References:
thank you.
