- Jul 8, 2008
Here is one of my modified {slightly longer, pointier, and narrower blade for easier turning in cuts like peeling an apple} Carter Pattern neckers, decked out with a 440c blade, Cocobolo scales and brass pins. this one is a super light, nice and thin, light to medium use utility knife, for daily cutting uses such as opening mail, trimming fingernails, peeling an apple, making a peanut butter and jelly sandwich, ect... of course they work great in the field for small game, wild turkeys, and trout. this pattern also works pretty good on game up to the size of antelope and smaller whitetails!
OAL- 6 7/8"
blade- 3 1/4" long tip to scales, .065" thick at the spine, .028" measured 1/4" behind the edge, and .013" thick at the shoulder of the edge. 3/4" wide
steel- 440c oil quenched from my PID controlled heat treat oven and double tempered for a really nice performing blade that takes and holds a great edge and yet is easy to resharpen!
grind- a full flat grind, sharpened on a Smiths 325 diamond hone with micro bevels, to an agressive razor edge
finish- A45 with blue scotchbrite belt finish.
handle- Cocobolo with brass pins. handle is finished with 200 grit with the lines running lengthwise with the handle so it looks good yet isn't slick
sheath- .060 thick kydex with small black rivets. stripped paracord, easily adjustable, and it is cut for my necker safety feature.
weight - 2.45 ounces for the total package of knife, sheath and cord. That's about the weight of a Zippo lighter!!!!!! for the WHOLE PACKAGE!!
I did a few videos on youtube on my 2 lines of neckers:
to explain what I am after in a neck knife
and a destructive test of the Carter style necker
here is the youtube series on how I came to my 440c heat treat
https://youtu.be/apW82MT8VnM
$135 plus $5 for shiping/insurance to CONUS. I can accept paypal Joe357m@bresnan.net or money order.
1st to post "I'll take it" gets it!!!
Ships within 48 hours of payment priority with ins.
Feedback appreciated, and thanks for looking!
If you would like one like this one or different, PM or email with details!
OAL- 6 7/8"
