.45acp vs. 10mm
I own a few 45's, but I am hearing good things about the 10mm rd.
From what I am reading, the 10mm typically yields higher velocity and energy, and in most configurations allows for more capacity. I hear some favor this round for self defense at home and in the wilderness.
I just wanted hear some thoughts from any of you that own a 10mm handgun, and about how it really stacks up against the .45acp.
I realize accuracy and recoil will vary from weapon to weapon, but in general, how does the 10mm compare to the .45acp?
Thanks
I don't own one (yet), but I've got about 500 rounds through a 10mm S&W 1000 series. The biggest advantage is energy transfer-if I recall, initial ballistics tests were unreadable because the round was shattering the ballistic gelatin... I found recoil to be manageable. Recoil is sharper, faster, allowing for faster followup shots. Of course ammunition availability is an issue, unless you're reloading. Muzzle climb was there but seemed to be predictable, coulda been the commander sized barrel.
The 10mm is like having a 41 mag in a semi auto. There have been deer size game taken with the 10mm. It has good range and shoots flat. It is a good all around weapon. Kevin :thumbup:
I've carried a Glock 29
and a S&W Model 610
for several years now with 180gr JHP from DoubleTap ammo. I also carried this S&W 25-14 in 45ACP for quite a while but the 10mm just seems like a better performing round, at least for me.
IMO the 10mm is an excellent round for self defense. My loads from DoubleTap are rated at 616 ft lbs of energy out of a G29. DoubleTap makes a 45 ACP load that also runs 616 ft lbs but out of a 5" barrel 1911. Not saying the 10mm is better but for me the same power level in a smaller package as well as 2-3 more rounds just seems like a better way to go.
Thanks
I had a Delta Elite chambered in 10 mm that I traded away many years ago when I saw the writing on the wall. The weapon was superb, but round never quite lived up to the hype built up around it.
Jeff Cooper is attributed as the primary motivator behind the round, originally as a medium velocity round. Norma of Sweden collaborated with Jeff, but developed a much hotter magnum loading designed to showcase the round in a new CZ75 clone called the Bren 10.
Jeff Cooper conceived of the 10 mm originally as an improvement over .45 ACP with specific goals in mind. Things got out of hand when the marketing firms of both Norma and Dornaus & Dixon got involved and soon the round was touted as the king of all man stoppers, a barrier buster that could pierce car bodies and windshields while still disabling assailants. It was even touted as having a "magic length and width" to reduce jams (this proved to be total hogwash).
The most high profile LEA that took interest early on was the FBI with several LEAs following the FBI's lead (assuming with more resources at their disposal they were likely to get it right). The FBI started looking for a new round in the early 80s, with increased interest after a shootout in Miami involving the FBI led the ballistics folks to believe they were "outgunned" and "underbored." The report indicated several solid hits were scored by FBI agents that should have disabled the heavily armed and unarmored assailants but failed to do so.
The FBI wanted it all: penetrate a windshield or a car door and still penetrate at least 10" into ballistic gelatin, hold more rounds in the magazine then the old .45 did (double stacked .45 ACP pistols were still pretty rare), be flatter shooting then the .45 and at least as good as the 9 mm in this regard, while imparting more disabling energy into an assailant. FBI thinking at the time was a round with at least a .40 caliber diameter and 140-180 grains was needed to achieve all of these goals.
Where things went wrong is now academic. It was assumed all agents would get new (and still quite excellent) S&W .45 ACP sized frame pistols in the new chambering, replacing the lighter 9 mm and revolvers fielded up until that time. Around this same time, there was a push to encourage greater diversity in agents the bureau was looking to hire. To address the diversity requirement, problems were identified by the trainers with the new weapons and the round they fired that was giving them a very hard time overcoming. The FBI relaxed requirements for certain physical attributes in terms of size and strength and in particular for the need to accommodate female agents.
The 10 mm was harder to tame, required more training (a lot of flinching, trigger yanking and scenarios in closed spaces and dark rooms were cited), required larger, heavier framed weapons that were less comfortable to carry and harder to conceal. The size of the grip necessary to accommodate a long round like the 10 mm in particular proved to be a problem for agents with smaller hands and many female agents. While depth of projectile penetration had been an important criterion initially, the bureau began to worry about liability in the event a round overpenetrated and injured or killed someone for whom the shot was not intended for. Lawyers being lawyers, this weighed on the decision for what was to follow, but the writing was already on the wall for all of the other reasons already mentioned.
Where a double tap was fairly easy to master with a 9 mm using standard pressure loadings, the 10 mm even in it's cooler loading relative to the Norma magnum loading still suffered substantial dazzle, blast and recoil compared to 9 mm or .45 ACP. The first attempt to salvage the decision to go with the 10 mm was to reduce the pressure of the loading, resulting in the "FBI loading" or "10mm Lite." Weapons remained of the larger frame necessitated by the longer case even if much of it's original velocity and associated recoil were gone. It also lost some of it's flat trajectory, barrier penetration and soft tissue disruption benefits that drew the bureau to the round in the first place.
S&W's design team saw an opportunity and acted upon the modified list of requirements provided by the bureau. S&W shortened the case, creating the .40 S&W and allowing the FBI planners to save face a bit by phasing out the full sized frame 10 mm S&W for a new procurement for 9 mm size weapons that could provide a bit more ballistic performance then standard pressure 9 mm could in a package that weighed no more than the 9 mm pistols previously favored. Issues with blast, recoil, the size and weight of the weapon were largely solved, though original advocates for full power 10 mm referred to the new round as .40 "Short and Weak." A few agents continued to carry their originally issued large frame weapons as a matter of choice, though increasingly the only loading they could obtain was the lower pressure "lite" loading, making any advantage largely moot. .40 S&W was born and is standard issue for a substantial percentage of police agencies in the US and even in other parts of the world.
The interest in 10 mm waned almost as quickly as it emerged. By the early 90s the rollercoaster ride was largely over. I traded in my Colt Delta in '93 and don't regret it, even though it was a fine weapon.
At this point, relatively few manufacturers still make weapons chambered for the 10 mm round or load ammunition for it. The two loadings available for it have few variations - the original high power loading, still mostly a Norma offering, and the FBI Lite version, made by just a few more. I wouldn't say 10 mm is dead, but the expectations were high and it never really measured up to what were probably unrealistic goals to begin with. Handloaders are keeping 10 mm alive and it's resurgence as a niche semiautomatic hunting round is probably all we can expect.
With the completion of surveys on terminal ballistic performance of several rounds compiled over several decades, it was determined that despite all of the hype, 10 mm didn't perform much if any better than .45 ACP and 9 mm it was trying to displace. 10 mm also failed to meet or exceed the real-world performance of the .357 magnum despite having similar recoil and blast. It also trailed the .41 magnum despite Norma's attempt to duplicate the cooler loadings of that round with the 10 mm. 10 mm is also a more expensive round on to shoot relative to .45 ACP, 9 mm, or .40 S&W due to substantial differences in production quantities. For hunting, there are few choices in heavily built bullets appropriate for larger game animals.
If you wanted to hunt with a handgun, a .357 or .44 magnum would probably be the better choice given variety of factory ammunition available, cost and the ability to use less expensive ammo to practice with the weapon more often. 10 mm semiautos give you more rounds in the magazine, but for hunting use, this shouldn't make any difference - markmanship, shot placement and ammunition suitable for the game your are harvesting is what counts.
I have hunted with friends with Glock 20Cs and while I enjoyed shooting them, my Ruger wheelgun with Hogue grips in .357 mag was more accurate and no less pleasant to shoot (custom shop ported barrel).
If I were dead set on a semi-auto for hunting and target shooting use (I myself am not), I'd go for the .45, but not necessarily limited to .45 ACP. I'd go for one of the few handguns that is available in .45 Super and gain the benefit of chambering the old low pressure .45 ACP as well. .45 Super has a reinforced case and the handguns have a redesigned chamber with more complete support of the case to avoid case rupture that would occur at the pressures .45 Super is designed to operate within (pushing into the realm of +P+ .40 and 9 mm loadings).
There are some excellent handguns in .45 Super (Kimber, HK, SAI, etc.) and all are solid (if expensive) and well put together, accurate weapons. I've shot the HK USP and would like a try on the excellent Kimbers when I get a chance. If you are for want of recoil and blast, .45 Super won't let you done. If .45 ACP is well mannered but slugs a slow bullet with a rainbow trajectory, Super flattens out the trajectory and gives you what 10 mm was supposed to give us, while preserving the old venerable .45 ACP for cheap practice ammo on the same weapon - cannot be beat in my view.
There are a fair number of .45 caliber hunting bullets thanks to the long life of .45 Colt that could be handloaded if you so choose. Being a fairly new semi-auto round, choices for factory loaded .45 Super are few to none, but its more logical in my view than doing the same with 10 mm given the similarities in performance between hot loaded 10 mm and .45 Super, plus the benefit .45 super handguns have by retaining .45 ACP backward compatibility.
In the end even Jeff Cooper, the sage behind the 10 mm effort, went back to the .45 ACP as a general purpose carry round and hardly mentioned the 10 mm again before his death a few years ago. I think there is a lesson to be learned there.
-E
Hard to argue with Coop.... :D
I don't have any practical experience with a 10mm, so my thoughts are strictly personal. The 45 acp has been proven over many years to be an effective, reliable, and easy to shoot (for most people) round. My 5' 4" wife has been shooting 1911's for years and has no problem with Commander or Gov't sized 1911's.
I don't put much thought into ballistics charts, never have. I prefer to make my decisions on actual field results. I personally think with all the premium bullet choices these days, the 45 acp has become an even more effective round than it ever has been.
Splitting hairs in a few feet for seconds in handgun calibers for me, is pointless. IMHO, a person is better off getting a quality pistol, lots of ammo, and practice, practice, practice....
The other huge reason for me to not consider changing calibers is that I already have a lot of pile of premium magazines for 45 acp, as well as thousands of pieces of brass.
My feelings are the same for the 40. I know there are people that like it though, and thats fine. IMO it was nothing more than a marketing effort to increase sales, just like the short mag rifles. But thats what keeps companies in business, so its all good
However, if you do want a 10mm, its a great excuse to get a new gun :D
Another option is to convert your .45 to .400 CorBon. The .400 Corbon is a .45 case which is necked down to .40 bullet and usually only requires a barrel change. The ballistics are a tad better than the 10mm.
From the CorBon site:
10mm
135gr JHP- 1400fps, 588ftlbs
150gr JHP- 1325fps, 585ftlbs
165gr JHP- 1250fps, 573ftlbs
.400 CorBon
135gr JHP- 1450fps, 630ftlbs
150gr JHP- 1350fps, 607ftlbs
165gr JHP- 1300fps, 619ftlbs
I recently bought a S&W model 610 revolver, six inch barrel, N frame. This gem shoots both 10 and 40 using fullmoon clips. It is a delight to shoot with 10mm, very low recoil with the heavy N frame and the longer barrel gets good performance and accuracy from 10s out to 200yards and beyond. Also, heck of a really noticeable difference between 10 and 40 when shot back to back. The 40 is an okay round but a real 'whimp' compared to the 10mm. As for comparisons with the 45ACP, I won't weigh in on that. I've carried various 1911s and other 45s, for example H&Ks, for close to 60 years and wouldn't change if you paid me. I have three handguns I carry on duty with my dept as the mood or a premonition strikes me, a H&K standard 45 with 10 round mags, a Taurus 1911 with 8 round mags, and a S&W 41 mag with six inch barrel and a bunch of speed loaders. Say what you will about Taurus but mine has performed flawlessly and IMO is an all around better firearm than my Colt National Match.
The 41 Mag. is a really nice round. Shoot one if you can. I know you'll like
it. Very close to a 10mm. ;)
Badhammer how is that S&W Model 610 say compared to a 357? or 38spl?
Not sure what you mean. It's a 10mm so ballistically it's head and shoulders above a .38 Special and beats out all but the heaviest hunting loads in .357.
If you mean size wise it's a N frame S&W so that while it has a fairly compact 2.5" barrel it's still a good size revolver.
Like Old CW4's Model 610 mine uses full moon clips and shoots .40 S&W as well as 10mm. Pretty handy to as I don't usually shoot reloads in my Glock 29 or 35 so I run new ammo through the pistols and then reload the brass for the wheelgun.
10mm
.400 CorBon
There is a good reason .400 CorBon the numbers above look like this - that's one hot loaded .400! Normally .400 CorBon is somewhat less than a warm/hot 10 mm loading and above a typical .40 S&W loading (including +P). Granted, .400 CorBon has support from several major manufacturers, but it's a boutique caliber and all the same issues with 10 mm apply, only more so.
To each his own.
-E
I used to shoot a lot of IPSC locally, and I have both a Glock 20 (10mm) and a Glock 21 (.45 ACP). Shooting matches with both pistols, alternating which I shot first on each stage, I consistently shot better scores with the 10mm. I was actually running higher power loads in the 10mm than I was in the .45, yet I shot better times and better scores with the 10, even when required reloads erased the advantage of the extra two rounds in the magazine. On metallic silhouettes, the 10 completely outclassed the .45, especially at the 150 and 200 meter targets (yes, I have shot 200 meter targets with a Glock).
The 10mm can be loaded down to a very manageable level for target practice and plinking, and it can be loaded up to levels I wouldn't hesitate to use on deer. The one thing it will not do that the more popular .40 S&W will is fit in a 9mm sized gun. It does require more dedication to master, but I certainly feel it was worth the effort.
Out of the dozens of handguns I own, the Glock 20 is my bedside companion.
A friend that worked in a gun shop, gave a Taurus 45 some very hard testing.
Like myself, he has shot 1911's and Glocks for years, and was skeptical.
He was actually impressed. Good accuracy and absolutely zero feeding or extracting malfunctions using ammo ranging from low grade factory loads to very hot hand loads.
The only Taurus I owned was a short barreled 357 about 10 years ago. IIRC I picked it up for about 175 bucks new. It was a great pistol. Smooth action, good timing and was finished nicely for the price. I would probably still have it, but a friend wanted it, and was willing to trade a very nice earlier Springfield 1911 for it. I already had about 15 1911's at the time , but he knew I couldn't resist :D
Is your Colt NM a Series 70 or earlier ? When I was collecting Colts, I ended up with a NM series 70, and it was disappointing
When I first started shooting Glock matches, I used a 21. One guy asked me, Did you bring a big enough gun? Everyone else was shooting 17's and 19's.
I've shot at 100 yards, but my eyes are so crappy now, I'm not sure I would be able to see the target at 200 yards :D
Sorry to drift a little in your thread 5.56. But I do like to talk guns :D
...given the 10mm's rise and fall, I have to wonder about the value and future of the .357 Sig.
Thanks for all the info guys
I own a Glock 21 .45 already and I am eyeing the Glock 20 10mm. I don't doubt either ones effectiveness against a human target. One main concern with my .45 would be it's effectiveness against a large animal. I don't plan on hunting with a handgun, but here in the mountains of CA we do have black bears.
Do you think 165gr +p corbon .45acp would be enough in a bear attack scenario? How about the 10mm?
I have a few magazines filled with Corbon for my 1911's and Glock 36. In all honesty, I've never used them on any animals though, just ran some through to check function. I prefer 230 grain +p's in my 45's. Whether its for 2 or 4 legged animals. I like the idea of having the heaviest bullet possible. As much faith as I have in the 45 acp, I'm still not completely mentally convinced it is a great round for big bears, but it is what I carry everywhere. I have yet to talk to anyone that I know for certain(you know how stories are) that has used one on bears.
Shot placement is everything there is actually a crazy guy I know that has killed deer hunting with a Glock 19.
338375, Earlier. I built mine from parts and a NM slide, barrel, bushing, etc., more than 50 years ago and on a cheap Essex frame no less. I still don't exactly know how I did it but this pistol has a trigger pull of a bit less than 1.5 lbs and it has never double fired. I've done innumerable trigger jobs on every type of gun out there but have never been able to duplicate the smooth and almost too light trigger on this NM. I even carried it for a while on duty years back but was always nervous with it drawn when in a tense situation. I sure didn't want to shoot accidentially but I didn't have the heart to stiffen up its trigger so I got another 1911 for duty carry. Yeah, I know, keep the trigger finger outside the guard but, when you're pussy footing down a pitch black alley after a perp you know is armed and nuts, I just want to have to only twitch to return fire with no other motions required. A heavier pull is best for those situations so the NM was retired to range firing only. I've been offered 2.5k bucks for it and I wouldn't take triple that. BTW, over a bench or table and at 20 feet or so, it will put round after round in the same bullet hole. It makes a kind of flower with all holes overlapping. No bull. I've won some serious money doing that with the NM.
