Hmmm...I'd really like to do that to mine. Do you have any info on the hardware you used or how you did it?
Here you go, just drill a 1/8" hole and then tap these in. The screw going in will spread and lock the inserts in.
http://www.mcmaster.com/#92394a111/=130x62q
So you don't have to use any kind of adhesive? I assume you've done this on other militaries...they all holding up well? Ever have any issues?
You don't have to and I didn't do it on this one. I did put a dab of super glue on the ones on my CRUWEAR Mili, but I don't think it was necessary. I have only had the clip on and off a handful of times, but that should be pretty typical. I did the mod in late 2013. Original thread with some more info: http://www.bladeforums.com/forums/showthread.php/1123113-Tapping-into-G10-and-only-G10-for-screws
I took mine apart and gave the blade a strong instant coffee soak for ~3 days (changing the coffee each day). You just need to make sure you clean off all of the oil on the blade, otherwise there will be spots that don't darken. I probably should have soaked it for even longer, but I couldn't wait to start carrying/using the military. Now I just need to clean up the edge and tap it for tip up carry!
Too early to tell. I've only used it in the kitchen for a half a dozen times or so and broken down a box or two. So far I don't see any change, but only time will tell.
