- Oct 17, 2015
Nope, all on display so its easy to pick one out.Do you have your knives sorted Alphabetically? It's amazing how quickly you can produce exactly what we need. Most impressive!!!!
YesCould you say more on this?
Would the steel decide the use for you, or would it be the grind?
I'm a little bummed that the flat grind is pulling so far ahead of the sabre grind... But on the other hand, I feel like a flat grind is probably better for the type of tasks I'd be comfortable doing with a D2 knife.
This thread kind of has me thinking though... For you guys, does the steel decide what you designate a knife as or is it the grind? (I should probably ask this is GKD)
For instance, given the choices of; 5160, D2, sabre grind, and flat grind, I would go with 5160 and a sabre grind for a hard use camp knife and D2 and a flat grind for a light use/utility camp knife. But what if the choices were either D2 with a sabre grind or 5160 with a full flat grind?
I'll go with the majority view over one opinion repeated many times.
D2 and Flat grind will make a fine knife.
I need to see it drawn with a secondary bevel. Without a secondary bevel drawn I don't get it.Despite my better judgement; I will entertain...
But first; if you're lacking a basic knowledge of simple, 6th grade Geometry, you may never get this. That is fine though, because in most cases the minutiae is irrelevant for everyday cutting tasks.
If we go waaaaaaaay back, I asked about the blade thickness because it's going to determine the efficiency of the blade grind, and in some regards it will also determine what you use the knife for. It's not as simple as picking a steel to use and a grind type when the thickness is unknown unless you're just making something for the shelf. Would you use a fillet knife to baton or chop? Probably no more than you would use Buck's Froe to fillet a fish; right?
These are scale drawings. What I can't provide is specifically what radius is used for someone's full hollow grinding because, well... there are options there. The rest is simple, 6th grade Geometry.
Key:
The 3 on the left are drawn with ~.120" stock (same as a 110).
The 3 on the right are drawn with ~.188" stock (roughly 3/16").
The two in the center are drawn 2" tall.
The next shorter ones are drawn 1.75" tall.
The shortest ones are drawn 1.5" tall.
The red is a full hollow ground profile.
The pink is a full flat ground profile.
The blue is a saber grind at 1/3 blade height.
(Scandi because of the lack of a secondary bevel, if you're following the rhetoric.)The yellow is a convex grind at 1/3 blade height.
None have secondary bevels. No, I will not redraw them with secondary cutting edge bevels. Use your imagination...
The "shoulder" is where the saber and convex grinds start.
Something to think about:
The .188" thick blade that is 1.5" tall and hollow ground (red on right) is similar in thickness to the full flat ground .120" thick 1.5" tall blade (pink on the left). The same can be true for each when you compare the hollow ground .188" to it's flat ground .120" counterpart.
Draw your own conclusions.
That's all I got...
good post, Sir. thank you.Despite my better judgement; I will entertain...
Key:
That's all I got...
Key:
That's all I got...
it's a done deal now but MT_Pokt post got me thinking....is d2 best choice for the ffg? sure work well enough or buck would say nope to it........ but did we all vote for best choices? maybe wrong thread for this discussion.....sorry if going off topic too much......
