A Brief Look at the Gransfors Bruks Scandinavian Forest Axe (Review)
I know that the Gransfors Bruks Scandinavian Forest Axe is not nearly as well known as its smaller cousin the Gransfors Bruks Small Forest Axe. As such, I want to take a brief look at the two, so that people who have never seen a Gransfors Bruks Scandinavian Forest Axe have a better idea of the point of reference.
Specifications:
Manufacturer: Gransfors Bruks AB
Axe Head Weight: 2 lb
Axe Length: 25 inches
Axe Head Material: Unknown Swedish steel; HRC 57 on the Rockwell Scale
Handle Material: American hickory
Cost: $130.00
The axe is everything you would expect from a Gransfors Bruks axe. The alignment and finish are perfect. It comes with a nice leather sheath. Everything seems to have been well thought out and checked before the axe was put on the market.
The Scandinavian Forest Axe is a serious tool. It has a much more substantial feel than the Small Forest Axe, although it is still light enough to be carried in a backpack or used with one hand when carving. This size axe however is towards the high end of what I would consider carrying in a backpack over an extended distance.
Here you can see the Gransfors Bruks Scandinavian Forest Axe next to the Gransfors Bruks Small Forest Axe.
The heads of the two axes are identical in shape with that of the Scandinavian Forest Axe being proportionally larger. The head is half a pound heavier than that of the Small Forest Axe. The attachment method is the same, and has proven to be very secure.
Just like with the Small Forest Axe, the head expands a bit too abruptly for my liking when it nears the eye. This takes away from some of the splitting efficiency.
The balance of the axe is almost perfect; something that becomes very important with axes this size. As you can see, the balance point is right near the head, and the head sits almost horizontally. The bit is only slightly heavier than the poll, and that is why you see it tipping down by a small degree.
The handle of the Scandinavian Forest Axe is about five inches longer than that of the Small Forest Axe, and the grain is very high quality. The Scandinavian Forest Axe is the one on the left.
The performance of the axe is great as expected. There is nothing here which would deviate from what is expected from a Gransfors Bruks axe.
Ross
http://woodtrekker.blogspot.com/
thanks for the review!
i purchased on last summer. i heat exclusively with wood (around 7 cords a year) so i got it primarily for delimping trees but also use it camping, etc..
man do i love it! previously i used my estwing (which is a fine axe) but it just can't compete with the ole' GB. worth every penny IMO.
