A More Useful Bottle Opener/Flat Screwdriver Secondary Blade Modification...
I thought I would show a modification of a common secondary blade often found in a multi-blade folder,...the bottle opener/flat screwdriver blade. I don't know about you, but I can't remember the last time I was in need of a flat screwdriver,....but LOTS of times I wish I had a solid metal fork, .....or something close!
It's near impossible to get away from having to use a plastic fork when eating out, and at some places like KFC the even worse "Spork" is the only option available. The short fork tines part of the spork are close to useless, which I guess is why I see most folks eat their chicken there with their fingers.
The only problem for me, and why I try to keep my fingers free of grease,...is that I also like to read a book while eating out. A few days ago I ate at KFC for the first time in a long while, and the Sporks have definitely gotten thinner and flimsy-er. It would bend long before picking up a piece of chicken from the pieces I had already cut with my early Case XX 11031SH sheepsfoot blade. In the end I had to put my opened book under the napkin holder, and wipe my hands down between page turns. What a PITA!
Anyway, I began looking for another way, and a few days ago I bought a nice used GEC Crown Lifter folder in ebony from kysteve here on this site, and decided to use that as a project knife. The knife already had the blade etching reduced considerably, and been sharpened and carried a little, so was no safe queen. For the $55 paid, I figured I wouldn't be too upset if I messed it up, but that rarely happens to me. ;)
The first thing I did was spend about 1-1/4 hours beveling and removing the inner sharp edges of the steel liners, especially noticeable in the easy opening window. When the factory sanding was done there, a sharp sliver was still in place that really needed to be gone for me to want to carry it regularly. The outer corners of the ebony all around were also chamfered a little, just enough to take away the corner edge.
And then the decision to split the screwdriver blade using just a thin stone separating disc of my Foredom flexible shaft machine. Followed up with some use of a 1/2" drum sander to bevel the cornersbetween tines, and a fine rubber abrasive wheel to smooth between tines a bit more. Final hand sanding with fine 600 grit sandpaper gives a pretty good polish beteen the tines.
Does it work?,.....hell yeah it does! I just had some shrimp cocktails and broke out a block of cheddar cheese and cut some up. The tines are perfect for this sort of thing! I have no doubt it will work equally well for meat, fruit pieces, and the artichoke hearts I love at my local Wholefoods Market. Looking forward to that tomorrow.
Here are some picks of the work:
I'm not sure "why" I've never seen this secondary blade design option available commercially, as it gives even smaller pocket knives a useful utensil that is much more likely to get used regularly than a flat screw driver,...at least by me,.... and anyone NOT an electrician! (and on light duty work the screwdriver should still work, ....just be mindful you have a split blade to work with)
So here's my current kit for the local eateries using crap plastic utensils. The early Case XX 10131SH I've built up a healthy patina, and added the Easy Opening cutout as the spring is probably a 9 for most folks. The added finger choil is something I've come to rally enjoy on this one. Keeps the knife locked in even when hands are a bit wet, like when slicing ripe tomatoes and fruits.
...only thing left to do is to work on matching up the GEC #15 Crown Lifter's "Patina",...first thing in the morning! :)
The finger choil and Easy Opening cut out fit my hand like a glove too.....
This version of the Case 11031SH originally had the abrupt swedge stop on the knife's spine. I removed it and extended it back much like later ones came from the factory. On a carbon steel blade that corner can collect moisture, and well, ergonomically when I wipe my blades down after use it FEELS so much better this way! :thumbsup:
The other style bottle opener could be used as a can opener. I like your modification. DM
Hell yeah !
That’s the spirit.
I never realized the beloved GEC took so much finishing of their finish. Interesting. Case will be thrilled to hear that (they know how to consistently finish their liners).
(I have none yet GEC is too ADD for me to keep up with.
I have no doubt it will work equally well for meat, fruit pieces, . Looking forward to that tomorrow.
Do not wait ! Continue the testing NOW !
We must know the results !
In spite of your fatigue surely you can go on . . . YOU MUST GO ON !
You might want to wait until you get home to love them . . . might get arrested doing that in the store. :D :p
Sorry . . . sorry . . .
It is a conspiracy by the all powerful Spork People. They're from outer space you know and intent on slowly undermining the strength of the nation if not the world by slowly starving us of our strength. It's insidious but effective.
. . . oh and DO NOT let them catch on that you are not an electrician, only the electricians can over come them (the Spork People are complete morons when it comes to fixing their stuff and so need those who understand the intricacies of electron flow . . . all others will be " the first against the wall when the revolution comes").
I have been thinking of this knife of late. The screw driver serving as a light pry / wedging tool has some appeal. I have been thinking of getting one and putting a steep single bevel on the tip.
. . . I won’t be going there though I appreciate your work and am glad you have a fine set that pleases you. I have enjoyed reading your post.
WAY TO GO JoeJeweler ! ! !
Personally I bought a titanium fork and spoon when I worked in an outdoor outfitter’s. I use them daily now more than twenty years later. I love titanium anyway and they are very durable and very light. I slip them into my man purse ( thought that was prissy . . . here’s the prissy part) wrapped in cling wrap at the business end.
I too read everyday at lunch and have my whole life. Ever see a complete collection of all of Conan Doyle's Sherlock Homles adventures and mysteries ? Whole collections of Nevil Shute stories ?(highly recomend Mr. Shute ! ! ! ! ).
Half an hour a day EVERY DAY gets me through collections like that in no time. It is surprising !
That and my bicycle commute are the high points in my day out in the world. A world that is becoming increasingly onerous with each passing week. No longer do we ask “has the world gone mad ?” but in the famous words of Jim Carry’s Grinch : “I’m going to die, I’m going to die, . . . I’m going to throw up . . . and then I’m going to die ! Make it stop ! ! ! ”.
anyway . . . he said regaining a tenuous grasp on the finer things in life (books and pocket knives) . . .
where was I . . .
Thank you for posting your mod !
. . . for being one of my favorite handles I don’t have a one as yet. I need to remedy this !
I have my sights on the GEC Grinling Whittler but have not acted. If such an aquisition is even within the reach of a poor man.
The Beer Scout (? ) your’s doesn’t have the bail) you present might be a good first ebony for me.
PS : I love real (paper) books but have you tried the Kindle e-reader ? Easy to prop up and turn the pages while in the grip of a feeding frenzy.
PPS : No I'm not mad I just have too may quotes from books in my head.
Thanks again for your post !
Wowbagger,...LMAO,...and you're a man of few words much like myself! ;)
Had them out today, and the "fork" and blade have both started to take on some color. I didn't use the Case 11031SH as it's already pretty dark. It usually takes me just a few weeks to get a nice even patina,....but I eat slow (reading helps) so that's probably faster than some folks work up color on their carbon steel blades. The slop stays on the steel longer this way, and I only wipe it off to dry it,.... and only rinse to clean it when I get home.
I too prefer paper books, and most have been bought in thrift stores over the years for at most a few dollars. Kindle doesn't interest me,...have yet to find a kindle edition at those types of stores! hehe
cheers,
Joe T
Yes I hear you. I was looking at Burt Bacharach's autobiography yesterday on Kindle ~$13 and thinking that I am only going to ever read it once so a nice used copy would be just the thing. However amazon Kindle through their Prime membership which I have offers free "library" books to "borrow". I haven't looked there yet.
One thing I discovered : A Cold Steel Holdout one (the big one) is perfect to lay across both pages to hold the book open (knife closed).
Good talking with you !
