- Mar 12, 2013
Hey guys!
Just wanted to share a little something with you that I discovered the other day!
I've always had issues with my Evenheat kiln overshooting the target temperature when tempering... If the setpoint was 400ºF and the kiln was already warm sometimes it would go over-temperature by as much as 40-50ºF.
Well I finally worked out the issue the other day. I've always previously set my ramp speed for the tempering segment to '9999' however this was incorrect. When set to '9999' the controller basically runs the elements wide open until it hits the set-point, then corrects. This works fine for high temperature steps because of heat-loss, but for the low temperature steps it causes overshoots.
If you change the ramp speed to something like 1000ºF/hr the kiln will only overshoot your set point by just 3-4ºF before settling down. If you want fastest possible heat-up along with no overshoot you could likely chain some segments like this:
Seg 1:
Ramp: '2000'
Temp: 350ºF
Hold: 0
Seg 2:
Ramp: '500'
Temp: 400ºF
Hold: 2 hrs
That should get you to temp quickly with little to no overshoot.
Let me know how this works out for you guys, it's been working well for me! I'm using one of the smaller Evenheat 18" kilns with the rampmaster control.
-Aaron
Seg 1:
Ramp: '2000'
Temp: 350ºF
Hold: 0
Seg 2:
Ramp: '500'
Temp: 400ºF
Hold: 2 hrs
-Aaron
