- Dec 30, 2018
Hi, first post here but I’ve come here for awhile for information. I’ve been making my own knives as a hobby for a couple of years now. I generally stick with O1 or 1095. I’ve had success with both. I recently was mistakenly shipped a piece of A2. From what I read the process of hardening this steel seems excessive. I heat treat with a simple propane torch into a small fire brick forge. I don’t have the ability to raise the temperature at increments or for hours at a time. Most hardening info I can find suggests heating no more than 400 degrees per hour up to just below critical temperature prior to raising the temperature to approximately 1700 degrees.
Is it possible to still heat treat this steel in a simple propane forge? Can I treat this like O1 where I bring it to a temperature where it is no longer magnetic and then just let it cool in room air? Will this cause problems with my steel if I do it this way? Thanks for the help!
