A36 is actually a high strength structural steel and can be heat treated due to the high carbon level. Nothing mild about it.
Wow I thought you where joking that someone makes knives out of a36 but hot damn someone does. What thy are doing is carbarizing the steel. Basically heat the blade to a high temp in the presence of a carbon bearing material (old way was antler shavings and carbon powder I think) and the a36 absorbs some carbon into the surface. But just becaus you can harden somthing does not mean it will hold an edge. This has been tryied by others and yes it gets sharp but it was quite lacking in edge retention. And using a36 is crazy because for all intents and purposes it's a mystery steel in that it's alloy is not very defined like say 1018. That's just crazy that he is making blades that way. Also the hard skin is not all that thick and over time you will sharpen it enough to go through it.
