RyanW
Moderator
- Jul 17, 2009
I was given a .250" thick piece of Precision ground A6 to play with, I have never worked with it and am looking for details about Heat Treating it.
Through various searches I have found that it is an Air Cooling steel My plan is to heat it to the recommended 1575F - 1600F let soak for 30 minutes then remove from oven and place on my Anvil with a steel plate placed on top until it cools to room temp. I do not have any Stainless Foil.
then Temper at 450F which the charts say will get it to 58-59C Hardness range.
Any advice is greatly appreciated.
PREHEAT PRIOR TO HARDENING
Preheating is often not necessary depending on the size and complexity of the part. If a preheat is desirable, a 1200°-1250°F temperature should be used. Heat slowly.
HARDENING
Parts at room temperature or as pre-heated should be placed in a hardening furnace operating at 1525°-1600°F. After parts have reached the furnace temperature, hold 20 minutes for small parts and up to 45 minutes for large parts
QUENCHING
A6 is a deep hardening tool steel and will reach full hardness by cooling in freely circulating air.
TEMPERING
A single temper (one hour at temperature for small pieces; proportionately longer time for larger sizes) is usually all that is required with tempering carried out in the range of 300°-1000°F. For most applications, the best combination of hardness and toughness is accomplished at 350°-400°F. Specimens 1 inch square by 3 inches long were air hardened from 1550°F and tempered at various temperatures for two hours. The resulting harnesses were as follows:
Tempering
300 62C
350 60C
500 58C
600 56C
