- Jun 13, 2007
Anyone not use an edge beveler, but instead use a knife?
An edge beveler is one of the few things that I don't have, or have coming.
I cut out my first pattern last night and on a scrap I cut the edges off using my leather cutting knife (a Cold Steel mini tuff light). I'm pretty confident and steady handed, but the cuts weren't perfect. After sanding, dying (black) and burnishing with beeswax I can't see any flaws, but I didn't want to try it on the sheath blank without asking if I can expect similar results on longer straights. The test piece is only about 3" long. Obviously the sheath has a much longer edge to cut.
I guess what I'm really asking is if the wonky line of a freehand cut is easy to blend in with the above mentioned techniques.
Btw, those warnings about wearing gloves when doing anything with dye are totally true. Things went fine with the green dye, but not so smoothly with the black. Both bottle of Fiebings (4oz) had issues with the tamper seal. When pulling them off it left a layer of clear plastic between the opening and inside of the bottle. I guess it shook the bottle when I pulled it off the black dye causing it to spill all over my hand. The best part was that I didn't even have anything under it so I had to grab some paper towels while the dye had plenty of time to seep into my skin.
I guess living skin is sort of like leather because it did a fantastic job of dying it!
