That's what will probably happen, I would like confirmation from Cold Steel Knives that it will be considered a defect before shelling out more money to ship itIve opened and closed mine a ton of times, still looks perfect. id send it in for a replacement of the whole knife.
The measurements show the problem, and how could this possibly be a counterfeit when these knives just came out?They will have to inspect to determine what happened and also to see if it is genuine Cold Steel. Inspection is standard practice before making any decisions or confirmations
As you say, they'll need to see it...so what's the point of calling if a rep can come here and actually see pics of the problem? If they're just going to say "Yup, locks up tight...no defect" then why waste $10 to ship it to them?They will still want to inspect the knife to see what the problem is so they can evaluate what must be done if it is due to manufacturing. Call their Customer Service.
Thanks, should I address it to someone specific? You can PM me the detailsDoesn't seem right, send it in and we'll check it out.
I could be remembering incorrectly, but I thought demko said that he designed the scorpion lock after desiring an easier to manufacture lock than the triad.Andrew Demko himself has spoken about how absolutely CRUCIAL it is to this particular model to have spot-on specs around that pin/notch area. I'm not surprised at all the huge difference in diameter from end to end across that pin has caused you problems.
It'd be interesting to see if pin + notch would ever wear down to a happy medium and "settle in."
Not suggesting you try Chip...just one of those 1000 little "what if's" that flit thru my mind on a daily basis.
They provided a return label within minutes. Dropped at FedEx this morning, should be back to you in a couple daysContact our customer service using the info in our signature. They will give you directions.
Shows as being delivered, now we wait to see what Cold Steel Knives finds upon inspection...
We're getting after it, not to worry!
