- Aug 20, 2018
Does anyone know of any good techniques for adding a sturdy crossguard to a common machete such as an Ontario or Cold Steel without any kind of special forging equipment?
"Sturdy" is the problem. Whatever you put on is going to be shaken loose by chopping at harder targets unless you attach it by welding or tight fitting (like the Woodsman's Pal).Does anyone know of any good techniques for adding a sturdy crossguard to a common machete such as an Ontario or Cold Steel without any kind of special forging equipment?
Ugly as sin, but you can't argue the effectiveness.
First, I don't see why you would need a guard on a machete... Second, I'd hate to drill the most stressed part of a knife. Silver soldered, perhaps (if the tang is left unhardened...). Third, that bolted-on contraption is just horrible...No offense to anybody but I'm definitely a no-guard guy. So, here you go.Use a carbide bit to drill some small pin holes in the base of the blade where the guard will go, and rivet it on.
again not pretty, but if the OP is concerned about preventing his hand from slipping up on a machete, this will do the trick for almost nothing.
That's my current idea so far. I'm going to give that a try first.
As for why I'm doing this, it's because machetes, much like tomahawks and large survival knives, are for me uniquely suited to the dual-role as both tools and weapons. In my opinion, it is an abomination for any kind of blade with even just a vague secondary use for combat to lack a proper metal crossguard, because this omission eliminates an entire dimension of combat capability, which is the ability to block and parry an opponent's blade (machetes are cheap, prolific tools routinely used as assault and murder weapons the world over) when it is not possible to evade his strike by any other means. Furthermore, I have hiked, camped, hunted, fished, and practiced wilderness survival skills for years, and I have never found a crossguard to interfere even remotely with any task associated with these activities.
