I am a martial artist who likes knives, and I've taken on a project with my 11 yr old son (also a martial artist) to build two pair of Sai. Since making knives is new to me, I thought I'd get some advice.
The style we're thinking of making resembles an '03 bayonette, except the guard (quillon) is a long, curved piece which looks like a set of horns curving forward. The butt (pommel) is a striking surface which also acts as a counterweight, similar to those on medievel swords- the ballance of the piece should be just forward of the guard. Blade and tang should be one piece for durability, but round or scale tang may be used (round is more common, wraped with linnen tape or chord, or wire). The blade length will be about the length of our forearms measured from the point of the elbow to the tip of the outstretched fingers, though I may make his a little larger so he can grow into them. The blade must be double edged and should have a fairly large ricasso because the fingers must wrap forward of the guard. I'll probably use a flat ground blade for strength, though I'm open to suggestions on that.
My biggest problem right now is in choosing the right steel. The blade must take and hold an edge under abusive conditions, and do all the things a bladed weapon normally does. In addition, its primary purpose is defense against most any type weapon immaginable. It must parry or block blows from staff, nunchaku, swords, spears, chain, or just about anything you can think of to launch at me. It is also used to trap weapons and attackers. So the steel must withstand heavy impact to both edge and side, and must endure severe torsional stresses in entrapment situations. I'm thinking I may have to use a mild steel and a heavy bevel on the sharpened edges as at this stage tempering hard edges on a more flexable blade is a little beyond my capabilities (I'm not a metalworker). Any suggestions or pointers would be appreciated.
