TekSec
Böse Messer
- Dec 8, 2006
So I was messing around with my little stovepipe forge which just has some holes drilled into the feed pipe for air supply. It didn't seem as though I was getting enough air and the mix was too rich even though I had the regulator on the propane tank down quite a ways. So I took my air nozzle hooked up to my compress, turned down the regulator on the compressor to 10psi or so and set it in the last hole on the gas feed pipe. Low and behold I was no longer running rich, the forge ran at almost perfect atmosphere and a hell of a lot hotter. Is there any reason not to do this? I know a blower is the preferred method, but this seems to work. Let me know of any thoughts on this.
