- Jun 3, 2019
Just out of curiosity, why? Torque (or lack thereof), or maybe rigidity?with a small machine like that, it's best to stay away from a fly cutter
Lovely - more equipment to buy
Looks like it ... and it seems to sneak up on you. First “I have this HF 1x30”, then “all I need is a used bandsaw”, then “oh, I need a used drill press”, then “seems like a 2x70 will make a big difference (it does!), then “a portaband and swag table would make things mich easier (I use it all the time), then “seems like a disk sander would make a big difference for flattening” (still don’t have that), then is “I should start doing my own HT (still need to build that), now its “a mini mill would really help with Wa handles and stable drilling “( and it is clear what a rabbit hole that is). I would ask “does it ever end“, but I strongly suspect I know the answer to that one......Yeah...Knifemaking is not an inexpensive hobby. The Milling machine might be the least expensive item once you add up all the Tooling required to make a "CUT".
Oh there is going to be an End...When you declare this the is KNIFE I'm taking to the Grave just in case I need one!Looks like it ... and it seems to sneak up on you. First “I have this HF 1x30”, then “all I need is a used bandsaw”, then “oh, I need a used drill press”, then “seems like a 2x70 will make a big difference (it does!), then “a portaband and swag table would make things mich easier (I use it all the time), then “seems like a disk sander would make a big difference for flattening” (still don’t have that), then is “I should start doing my own HT (still need to build that), now its “a mini mill would really help with Wa handles and stable drilling “( and it is clear what a rabbit hole that is). I would ask “does it ever end“, but I strongly suspect I know the answer to that one......
The PM mills are good machines. They are really "inch" models, not an adaptation of a metric machine with useless dials, from what I can see. Buy once, cry once.
I’m looking at a mill for creating flat parallel surfaces(for scales and especially components for wa handles). It’s supposed to supply a more rigid and precise version of a drill press ... but I have yet to try / experience it... as DFK just said ... it seems a pretty universal observation that the dials are junk for positioning ... and plan on needing a DRO. I’m ok with that, as the alternative higher cost machine is expensive, and just plain too big for my spaceHmmm. I don’t have a drill press and was looking at getting one. Would I be better served with a mini mill?
What kind of precision you look for ???? 0.000001 on wood ? You will spend two hours on mill to flatten three piece of wood ? Come on Get disc sander and learn to use itI’m looking at a mill for creating flat parallel surfaces(for scales and especially components for wa handles). It’s supposed to supply a more rigid and precise version of a drill press ... but I have yet to try / experience it... as DFK just said ... it seems a pretty universal observation that the dials are junk for positioning ... and plan on needing a DRO. I’m ok with that, as the alternative higher cost machine is expensive, and just plain too big for my space
