American Axe History: Single bits
AMERICAN AXE HISTORY: SINGLE BIT DESIGNS
Hello there. I really love axes, and America is where most axe innovation took place, so I decided to read up on it.
I looked at many sources and archive footage, and compiled this little article, which I hope you enjoy. There is some theory involved as well, because there is very little, if any, research on the subject of axe geometry.
I've added sources at the bottom.
INTRO
Fully modern American axe designs have existed since before the American revolution.
To understand the origin of American axes, we must understand the history of American logging.
American states are essentially countries. Some of them are very large and have diverse geography, climate, etc.
Due to this, it’s difficult to generalize a state or region as harvesting one particular tree species and using one kind of axe. Multiple tree species were felled, and multiple types of axe were manufactured and used everywhere.
There are, however, general tendencies region by region, which we can take a look at. The big tool manufacturers did just this when they "standardized" American axe patterns and made a list of them over 100 years ago.
Some of these patterns, like the Rockaway, are based on very concrete examples, while others like the Wisconsin, Long Island, New England etc. seem far too similar to not be artificial distinctions and essentially one pattern which was forged across a wide region with small differences.
First, using a map from 1884, you can see the division of the North American continent in terms of forest types.
I see two major designs:
The hardwood felling axes of the south and to an extent the Atlantic coast, designed with cutting hardwood in mind. They tend to be big and heavy and have lugs, or ears. The point of these was to increase the contact with the handle and secure the axe head better. I believe these are a somewhat archaic feature, leftover from a time in the early 18th century when axes were not yet as broad and needed the extra contact with the handle.
Latter designs from the middle of the 19th century, such as double bits, axes with forged out phantom bevels, and axes from the period of the logging boom in the great lakes region of the US, were generally earless - they didn't need the ears. Patterns with lugs would still be forged by the big manufacturers, but these are more of an aesthetic element.
The other group I see is the narrower, smaller New England and Great Lake designs, which have no lugs, and were used for cutting primarily softwoods (white pine).
Due to Indiana's oak forests, the Hoosier pattern, probably developed with hardwoods in mind, would fit better in the other group
When I say "wide", I'm talking about the angle of the grind, when I say "broad", I mean the distance from toe to heel.
KENTUCKY PATTERN
Tom from Yesteryears tools mentions this pattern as originating in the late 18th century and describes it as a very heavy felling axe.
I wrote to him with some questions about axe design, then discovered he's been dead for 10 years.
Samuel Collins in a history of his company mentions manufacturing Yankee (light) heads in 1828 and starting production on Kentucky (heavy) heads in 1829. We could probly describe the Kentucky heads as the heavy southern hardwood axe, and the Yankees as the lighter Northern softwood axe.
The state of Kentucky is known primarily for its hardwoods. Oak, hickory, walnut, poplar, etc, which make up more than 70% of its forests.
The Kentucky pattern may have informed some of the lugged and broad patterned designs in the region, such as the Jersey and Baltimore Kentucky.
BROAD FELLING AND HARDWOOD AXES
Large, heavy, rectangular designs with a broad bit are preferred for cutting hardwoods.
Generally, it’s more difficult to penetrate hardwood. I asked Timbersports champion Arden Cogar Jr. about competition axes, and he told me that a long axe will cut deep in softwood, but not so in hardwood, making the broader axe more efficient in that case.
Softwood, due to knots and resin content, will generally stick to itself more, making it more difficult to separate and throw chips. Cutting it requires a long axe which will cut deep and slice its long, continuous fibers.
But going back to broader axes, they will make it easier to overlap your cuts because of how broad the cutting edge is.
A broad axe will also compensate for its relative lack of penetration compared to a narrow axe by cutting across a larger surface area.
The axe, due to its shallower penetration, will not bind as much. It is also easier to apply leverage to pull out an axe which is not sunken deep, due to the "wiggle room".
An axe also needs to clear chips – remove chunks of wood that have already been severed. A wide, broad axe (as long as it can still slice well) will leave less space for the chips and send them flying out.
AUSTRALIAN AXES
Australian axes, due to jarrah, gum and various other terrifying hardwoods (they have this thing called bollock or something) were even more robust, because these woods would break thinner axes. These axes are most reminiscent of the Connecticut pattern, but more massive. They have no phantom bevels, some are even convex - the cheeks jut out a bit. I imagine that when cutting these woods with very hard Janka hardness, you will hardly ever get your axe stuck so deep that you would need the help of phantom bevels to loosen it.
An interesting development in Australian axes is the oftentimes curved bit, which concentrates the force of the swing towards a singe point. This makes it less precise, because it is more difficult to follow a straight line cut after cut, but it also increases the penetration of the axe, which might have been precisely what these big, fat axes needed.
Another, possibly bigger factor, is that the heel and the toe of the axes were generally thinner and supported by less metal, making them more likely to break, so the blacksmiths started grinding or forging them back to counteract this, leading to a curved edge.
You can watch an Australian axe being used in this very beautiful video:
AXES OF THE 18TH CENTURY
The axes of the 18th century are primarily, if you look at pictures of old axes, wedge and half-wedge profiled. Their cheeks are flat.
Another distinguishing feature they have is their very large poll, which was reduced in future generations of axes. My theory is that loggers and blacksmiths gradually found out it was unnecessary, and the metal could be moved to the front, giving the axe a longer life.
Phantom beveled and hollow cheeked axes appeared at a later stage.
Phantom bevels were most likely invented by axe manufacturer William. S. Kelly, who noticed that loggers cutting greenwood were spending as much energy pulling the axe out of the tree as they were in chopping it.
True Temper catalog, 193X
They work by reducing the surface area of the axe, which in turn reduces friction, meaning the axe binds less when cutting.
As modern racing axes have what is called a hollow behind the bevel, the phantom bevels, or “wings” as they call them, are ground out primarily to reduce weight, according to one of the smiths from the Engineered For Axemen forge.
HOOSIER PATTERN
Another broad felling design is the Hoosier, Zeek, or Indiana pattern. It is somewhat reminiscent of later racing axes.
While its protruding toe, or upper corner of the edge, increases the cutting surface of the axe and helps with felling and limbing, it also reduces the functionality of the tool when bucking, or sectioning logs at ground level, because it can bury itself in the dirt and get snagged by a rock.
Indiana, I read on an article in fs.usda.gov, was primarily logged for the prized hardwoods in the south of the state, oak especially.
CONNECTICUT PATTERN
Connecticut, I read by Eric H. Wharton, had extensive chestnut forests, which had succumbed to blight and logging by the beginning of the 20th century, and were replaced by oak-hickory forests.
Due to chestnut's high tannin content, which makes it very decay resistant, you can still find dead chestnuts with salvageable lumber in Connecticut (so called "wormy chestnut")
A quote: Prior to the middle of the century it is said (13) that the settlers cut only the largest trees, "practicing forestry as recommended by forestry schools today.
Chestnut is a soft hardwood related to to oak, and Connecticut's hardwood forests could partially explain the broad felling design associated with the state.
WEDGE/HALF WEDGE PATTERN
The wedge and half-wedge designs are mostly associated with Maine and the region, one of the first places in US to be logged. Logging in the region started in the early 1600s.
These patterns are universal designs, appropriate for all kinds of tasks, and like many 18th century American axes, have a wedge or half-wedge profile.
Maine was renowned for its high quality laminate ("forge welded") axes, often manufactured by smaller companies.
RAFTING PATTERN
The rafting axe was used for rafting – binding together many logs into a raft, and then sailing them downstream large rivers to lumber mills. To bind the logs together, boom dogs would have been used – rings attached to the end of the logs, through which chains were passed. To beat the boom dogs in, as well as for other tasks, heavy duty rafting axes with hardened polls were used.
MICHIGAN PATTERN
Michigan axes oftentimes had rounded corners so that they wouldn’t chip on frozen white pine when logging in the winter.
Most logging in the North East of the US was seasonal work and was done in the winter. The logs slid more easily on compacted snow, and the cold would freeze the mud roads and make them traversable.
With the spring thaw, the logs would be driven along rivers to saw mills downstream.
HUDSON BAY PATTERN
The Hudson Bay pattern, in this particular design, was revived under the Collins Legitimus brand in the early years of the 20th century.
It’s beautiful and easy to manufacture, but its very narrow eye and long blade make it easy to loosen from the handle.
Older Hudson’s Bay designs were folded over and forge welded, had a narrow blade, a slip-fit style handle, and were similar to axe designs from Southern Europe, where they originated.
HB’s belong to a group of axes known as trade axes, as the Colonialists used them for trade, and often exchanged them for furs, of which beaver pelts were the most significant. Many people became rich from trading in beaver hides.
While people think Collins reinvented the Hudson’s Bay design, it’s not exactly revisionist, as one can see earlier examples which are remarkably like
the Legitimus line:
Such as the axe on the far left.
TURPENTINE PATTERN
The Turpentine, or Boxing, pattern, was used to make a hole in the bottom of a pine tree to gather resin, or “gum”, for the turpentine industry. The turpentine industry was strong in states with coastal pine forests like Florida and the Carolinas.
Swedish companies like Hults and Gransfors were exporting axes for the turpentine industry, and this pattern is probably the basis for the modern Swedish forest axes
THE CEDAR AXE
There is a surprising amount of info on the cedar axe. Yesteryears tools describes it as:
"a medium weight axe, either single of double bit, with broad curved cutting edges suitable for cutting small softwood trees and saplings. (also called Mexican cedar axe, balloon pattern, butterfly pattern)."
"Experienced woodsmen say that the specially designed axe is twenty-five per cent more effective for the purpose of cutting cedar than the old style chopping axe... "
"In the early twenties ranchmen of the cedar section of Texas began to hire cedar choppers to clear out the excessive growth, most of the choppers being migrant laborers from Mexico. These choppers complained that the axe in use was too heavy, weighing from three to four pounds. The handle was too long and the axe blade too short. These defects must be cured to create a more perfect cedar axe. Many were studying the problem and the solution was found by Henry Weiss of Kerrville, who designed the cedar axe."
The cedar in question, Juniperus ashei , is considered a native, yet invasive species in Texas
ROCKAWAY PATTERN
The Rockaway axe is possibly a pre-revolutionary design, made popular by William McKinnon a blacksmith in Rockaway, NJ.
You can read more about it in the article “The McKinnons and the Rockaway axe” by Bob Garay.
OTHERS
New England, Long-island, Wisconsin, Dayton, Yankee, were universal patterns used for cutting primarily pine. There is little difference between them – they are the smaller, lugless softwood axe of the North, possibly separated by manufacturers into different types to make it more interesting and alluring for customers. These are rectangular, moderately broad, have a curved heel and very lightly upswept toe.
A Dayton is pretty much a Michigan without the rounded corners. Or vice-versa.
In the Douglas Axe Catalogue from 1863, one can see that they offered Maine, Michigan and Ohio, as well as Jersey, Georgia, North Carolina and Turpentine patterns.
These axes wоuld have been used for cutting swathes of virgin forest with giant old growth, as well as on a homestead. They were manufactured in a various weights and sizes.
In Wisconsin, around the Black River alone, enough pine was logged to make a boardwalk 9 feet (3 m.) wide and 4 inches (10 cm) thick, which could go around the whole world.
Ohio exported some of the finest hardwoods in the world in black cherry, black walnut and white oak.
That's it for now! I hope you enjoyed this little article, and I wish good health and good spirits to you all.
SOURCES:
https://www.fs.usda.gov/.../learning/history-culture/...
https://www.wxpr.org/post/looking-back-winter-logging...
https://www.upperdelawarescenicbyway.org/.../logging.../
https://northernwoodlands.org/.../when-is-the-best-time...
https://www.wisconsinhistory.org/Records/Article/CS409
https://www.yesteryearstools.com/Yesteryears.../Home.html
https://clutchaxes.com/michigan-axe-pattern-uses-and-origin/
https://www.woodsplitterdirect.com/.../a-history-of-maine...
https://eec.ky.gov/Natur.../Forestry/Pages/Forest-Facts.aspx
https://www.furtradetomahawks.com/hbc-trade-axes---11.html
The Forests Of Connecticut, Eric H. Wharton
THE McKINNONS & THE ROCKAWAY AXE
By Bob Garay
A Museum of Early American Tools, Eric Sloane
A History of Weapons Of The American Revolution, George C Neumann
American Axes: A Survey of Their Development and Their Makers, Henry J. Kauffman
Sixteen Maps Accompanying Report On Forest Trees Of North America, C.S. Sargent, 1884.
Artisans of Australia: Timbercraft
https://youtu.be/dcoTnER4Efg
Log raft on Mississippi River photo ... I know where they were headed. The lumber capitol of the world at that time: Clinton, Iowa.
All that lumber from the Wisconsin Black River region (and from neighboring Minnesota and western Illinois) was processed in Clinton, too.
Clinton was the Lumber Capitol of the World in the 1800's. Another claim to fame: There were more millionaires per Capita in Clinton, IA, than anywhere else on this rock/in this solar system.
(I was raised in Clinton)
Good article. It took a lot of research and time to get it right.
Hey, nice post with info i agree with from my research.
Where does the first picture come from, aswell the 2 axe pattern group pictures?
Thank you.
OTHERS
New England, Long-island, Wisconsin, Dayton, Yankee, were universal patterns used for cutting primarily pine. There is little difference between them – they are rectangular, moderately broad, have a curved heel and very lightly upswept toe.
That's it for now! I hope you enjoyed this little article, and I wish good health and spirits to you all.
Written by Bozhidar Boyadzhiev.
SOURCES:
By Bob Garay
Nice thank for sharing that.
Is the 1863 Douglas catalog online?
Thank you.
A History of Weapons Of The American Revolution, George C Neumann.
Haven't found the Douglas catalog online.
There is a book by an author "Goodman" about the history of woodworking tools, and it shows illustrations of single and double-bit axe heads used in Crete from 2000bc to 1700bc that for all practical purposes are identical to USA axes of the 19th/20th centuries.
The ancient Hellenistic "labrys" double bit axes are generally regarded as being ritualistic in usage and would make very poor tools or weapons alike.
Brent, jup a example of a Persian Doubleaxe used as Weapon:
And a Doubleaxe from Sweden about 2500 bc:
This reminds me of thougts that supposedly certain tools were first invented in America like the Doubleaxe or the Pulaski. But then it gets discovered by People that never look at history that these tools were used centuries before in the "old world".
The Pulaski is really the funniest example, its often ignorantly said he invented the thing first, but then it comes out that "Kreuzhauen" or "Wiedehopfhauen" were used in the Alps since ages.
That is great, thanks for that, but the book I have is about woodworking tools. And besides, if a facsimile of a tool was used in a ceremony, it's appearance was modeled after a..............tool ! So put your thinking cap back on and throw your next poorly thought out assumption up.
Wow, man--looks like you forgot your manners when you went out the door this morning. Welcome to my ignore list.
Also for the record I cannot find any scholarly information supporting the use of Cretan double bit axes as tools. All mentions I've been able to find indicate that even the plainer examples of thicker form were found alongside other religious items.
I know this is an old thread, but I have some questions about the axles currently sold.
I have some doubts and decided to ask for help from those of you who have more knowledge.
Would the ax sold as a “European model” be the “Hudson Bay”?
And the ax they sell as a “Canadian model” would be the “Yankee” or “Dayton”?
Thanks for your attention.
Leocir Dambrós – Brazil.
The "European" model appears to be a German Rhineland pattern with an oval eye instead of a German "D" eye. A Hudson Bay typically has a flat top.
The "Canadian" model appears to be a Dayton.
