Bruce Bump said:
Yep Im sure. Call Devin Thomas. He taught me this trick. Ive done it for years on my blade steels including damascus. It doesnt work with L6 or 15n20 though because of the chrome I think. 1550 may work for them.
Typical lameller anneals will work with 15n20 (it doesn't have the chrome like L6), perhaps even the 1500F+, but L6 almost necessitates spheroidal anneals, it simply does not like to make pearlite. One does have to be careful on how they do the L6 spheroidizing, since it hardens so easily.
I have been using spheroidizing for many years now, and really like it for the completely stress free and dead soft characteristics. Also, since it is subcritical, one can refine grains to whatever level they wish and not mess with it in the subsequent anneal, recrystalization is not completed. This is why I do all of my grain refinement at the end of the forging operation.
In steel that is not hypereutectoid, there really is not much of the tell-tale spheroidal carbides because there is not enough carbon to ball up, in the time we have to work with, but things still get very soft all the same. Hypereutectoid steel will really respond to it, and if there are carbide forming elements present the effect will be more so. Going from a bainitc or martensitic structure will get the job done in no time because the carbon is allready in solution and can ball up quite readily.
Pearlite has the carbon and iron layered out in alternating lamellae of ferrite and cementite, this is why it is referred to as lamellar. The higher the soak temp and the longer the time the coarser the pearlite, due to greater seperation of the two. The process by which it forms on cooling is quite fascinating but a bit aside from the topic at hand. Lower soak temperatures, with less time will result in finer pearlite, due to the lesser degree of separation. normalizing 1084 will get you plenty of fine pearlite. Stuffing 1084 at 1500F. into vermiculite or wood ash will get you the course stuff. Coarse pearlite is softer but actually not as tough (kind of reverse of what is normally expected).
Trying to spheroidize pearlite will take a little longer than what most of us would care to spend, but then if it is pearlite, it is already annealed
There are always catches though, if you have a spheroidal microstructure you will need to increase your soak time to get all the carbon back into solution. I can get pearlite completely austenitized within 3 minutes in the salts, but I need 4-5 minutes after rebound to complete the job on spheroidized steel.
