...Kevin, do you happen to have the speeds for any of the Heatbath products? I would love to complete the chart. Heatbath has refused to answer my inquiries on several occasions...
It is hard to give exact comparisons since I am not sure of the parameters of the other test results you have there and what points the individual manufacturers measured from, but I do have a nickel ball number of 7-9 seconds for Parks #50, and 9-11 seconds for Parks AAA.
The concept of improvised quenchants is similar to the using O1 with just a forge topic. If all you have to compare with is your own uses or references of properties and performance, then it may be safe that everything is working fine, after all if the resulting blade cuts everything you want it to cut it is good enough isn't it? But when you start really dissecting the materials and processes in order to optimize both that is when subtle differences become much larger. Taking Rockwell readings on pieces of predetermined graduated thicknesses after the quench, and metallographic examination of the inside of the quenched part will reveal how much performance is really getting out of the material and the process, add to that the ability for complete repeatability at any time in the future and one can then change the definition of what problems there may be.
Saying that any given quenching medium meets all of your needs and produces blades equally capable of meeting all of your needs and thus works just fine for you with no problems is completely legitimate and accurate within that frame of reference. The only time I get a little testy is when the suggestion is made that there is no difference or nothing to be gained by a well formulated quenchant when coming from that same frame of reference.
Stacy, as I often do, I am in complete agreement with your post. But I would disagree with the notion that good quench oil costs two to three times what substituted materials would. I have done some "shopping" trips to research this concept and have found it to be one of the more faulty and erroneous reasons to resist a good supply of quenchant. If one has a reliable supply of quenching oil, and can buy in amounts that please the supplier, I have seen many of the substitutes cost as much as over twice the price and one still has to worry about the lifespan and stability after that expenditure.
One exception that I would strongly consider is edge quenching. Leaving all that hot metal just above the surface tends to just trash a good quench oil anyhow so perhaps something more disposable would be better for such an application.
