Yes, indeed I ordered one, in size XL (10cm blade size) and today it arrived.
Two surprises:
It IS possible to pull the blade out when locked closed - some 4mm. Seemingly it is no bug of certain copies, but a bug (or feature?) of the construction, since the lock is not tapered towards the closed blade, only towards the opened blade. Not really good. Maybe the reason is that the latch may get too weak if this quite narrow latch is tappered from two sides. Opinels do not have the problem since their lock ring is very broad. I also do not like this protruding handle of the Old Bear latch; my feeling as an engineer tells me "Don't do this!"
Second surprise is that the blade of my copy is marked W 1.4060 Nitrogen; I could not find a lot about this, but it actually may be a better steel than 420, maybe more like 440.
Further I noticed that the Old Bear blade has only 1.8mm thickness (compared to 2.2mm at Opinel No 10). So most likely Antonini uses 2mm steel plate, while Opinel uses 2.5mm steel plate before grinding down. I noticed it when I had the feeling that the blade of the Old Bear is somehow more flexible than on my Opinel.
If there is anything to repair, then most likely the main rivet/splint needs to be taken out as in the one video, while the lock ring of the Opinel can be strengthened or loosened using spring-ring pliers (or an appropriate slot screw driver...).
The Olive handle looks nice but there is no real finish in the sense that there is a sufficient layer of varnish.
Similar to some Opinel the blade does not move very easily. I need some time to test; on my Opinel sunflower oil helped a lot so that blade moves nicely while water cannot penetrate that easy into the head of the handle anymore. I will do the same with the Old Bear.
Last but not least the price. The cheepest Old Bear XL I could get, almost, was a Olive tree handle version for 22,80 Euro plus shipping (was an occasion at knifestock.de respectively knifestock.sk). Walnut would have been some 2 Euro less. I did not necessarily like to obtain an Olive handle but I also did not like to buy wood, which seems to come from outside Europe as the walnut handle or any laminated wood. There is seemingly no kind of budget version made from local wood like beech from sustainable cultivated forests as Opinel does. Olive is seemingly the only wood from Italy they work with. In general Old Bear prices at least in this blade size are quite high compared to Opinel; most well beyond 30 Euro. In comparison, for my Opinel No 10 I paid below 14 Euro plus shipping.
So given, that the Old Bear was some 65% more expensive than my Opinel, that the twist lock does not work properly for the closed knife, while having a protruding part and that the blade is quite weak for that size, I'd definitely not buy it again. If others would ask for a recommendation, I certainly would not recommend the Old Bear knife.
In Germany by the way at least since the 80ies the Opinels are somehow "the knife" of the boy scouts which made them known in Germany.
So now I climb out of the rabbit hole again!-)
