1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  1. Sharpe5097
    Sharpe5097 Gold Member Gold Member
    309
    Mar 2, 2017
    [​IMG]
    Can anyone tell me what kind of anvil i just bought.
    120 Acres likes this.
  2. Sharpe5097
    309
    Mar 2, 2017
    [​IMG]
  3. Sharpe5097
    309
    Mar 2, 2017
    [​IMG]
  4. Sharpe5097
    309
    Mar 2, 2017
    [​IMG]
  5. Sharpe5097
    309
    Mar 2, 2017
    Bout 100lbs
  6. 120 Acres
    120 Acres
    774
    Jan 5, 2017
    Old and well used.
    Congrats.
    Sharpe5097 likes this.
  7. The barefoot boy
    The barefoot boy
    132
    Oct 4, 2017
    Looks like it is about 100 pounds, maybe a bit more. I would take a grinder to the face to flatten a bit.
    Because of the condition there is no way to tell what company or anything of that sort.
  8. Sharpe5097
    309
    Mar 2, 2017
    It was purchased over 20 years ago in New Hampshire and has not been used since it was purchased
  9. Lieblad
    Lieblad
    Jul 24, 2015
    Hard to say brand or anything. Its fairly old and beat. Those holes are unique !
    Give it a dose of flapwheel & put it to use.
  10. Sharpe5097
    309
    Mar 2, 2017
    I will. Can i fill the divots on top with weld
  11. i4Marc
    i4Marc
    Oct 19, 2011
  12. running bird
    running bird
    206
    Sep 29, 2015
    Filling the divots doesn’t seem like an option, the material you add will be softer than the rest of the face.
    Clean off the face with a wire brush (rough, medium, then soft) then brush the rest down with a very fine scotchbrite pad and oil.
    I used this process for my Peter Wright when I got it a few years back. Took about 4-5hr, I went very slow during this cleaning, I didn’t want to remove too much material. Mine was in fairly nice condition when I got it, but if you just take it slow you should be able to clean yours up no problem. The horn of you anvil is is much nicer shape then mine, I’m a little jealous hahahahaha. Someone made a bunch of large cut marks in the horn on mine.
    I don’t see any way of telling the maker of your anvil. Just check to make sure it bounces a hammer (or a ball barring) on its face. Also be sure to check the all the faces of the anvil for cracks. When I bought mine there were 2 at the antique store I got it from. The first one I saw was bigger and had less rust, but after flipping it over I noticed a long fine crack running along the bottom of the anvil. So I skipped out on that larger one, never know if a crack like that will continue to grow.
Share This Page
