Any small EDC flashlight recommendation?
Hi folks,
I'm looking for a small flash light for my every carry. I'm wondering if you have any recommendation for a small flashlight (less than 3 inches in length and about 3/4 inch in diameter) that uses either a AAA or AA battery and has pocket clip. My budget would be $50 or less.
Thanks
Lots of options for that price.
Eagletac D25a, Thrunite t10 or t10s, L3 L10 or L10C, ITP A2 EOS, 4 Stevens Q Mini AA, Maratac AA, Olight S10 would all be worth looking at.
For a little more check out the Zebralight SC52W L2 or Spark SF5.
You planning on running 10440 or 14500 cells?
Fenix E12, small, powerfull, rugged AA flashlight. I own one and can say that all the positive feedback on this light is true and I have nothing negative to say. It is a little longer than what you wanted (3.5"). But this light fits in my jeans condom pocket comfortably :thumbup:
Thanks for your feedback. I'm going with the Thrunite T10. I really like the size and the thumb switch and the pocket clip looks like it will withstand beating.
Cheers
The fenix LD01 is a nice little edc flashlight. Its twist on though. I use mine as a keychain light. There are also other smaller fenixes available that meet your requirements. I would say the olight s10 baton but those run on cr123a & 18650.
The Maratec AAA is an awesome little edc light. :thumbup:
Specifications:
Executive Series
Packed in foil packs to preserve polished finish.
Glow in the dark Diffuser ( New for Rev 3 )
Glow in the Dark front o-ring around reflector ( New for Rev 3 )
Each light is hand finished.
Length: 2.6" ( Smaller than Rev 1 )
Diameter: .5"
Weight: 27 grams
Weight with battery is 40 grams ( 28.1 grams without battery )
LED Type: Cree XP-G2 R5 with a life span up to 50,000 hours. ( Newest & Brightest Emitter )
The New Orange Peel Reflector is aluminum alloy.
Flashlight body is machined of solid billet ultra conductive pure alloy 101 copper.
The lens has been treated with an AR (anti-reflective) coating.
Its proprietary circuit design features reverse polarity protection and runs off of one AAA battery that provides
Now with 3 levels of brightness ( Low / Medium / High ).
Comes with clip & o-rings
Note: this is a solid copper flashlight not plated
Machined from solid copper billet stock
Clip installed from factory to preserve finish
New Stronger Clip
Using a single Duracell AAA battery we got the following results:
Medium mode, 40 lumens output for upto 7 hours
Low mode, 1.5 lumens output for upto 55 hours
High mode, 138 lumens output for upto 70 minutes
Lol,the power went out at about 5am and the tiny little Maratec AAA in my pocket turned total darkness into the Las Vegas strip.:D:thumbup:
Olight S15 Baton. It rocks!! Never thought I would use that magnet so much. Clip design has allowed me to clip it to the brim of my hat on numerous occasions for hands free use. I have had many edc flashlights, and the Baton series are easy favorites.
