Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
When you say no up or down play, how are you evaluating that? Just wondering if my standards are unreasonable or not.I just opened my Micarta Maverick.
Seems pretty good to me on first inspection.
Centered. Smooth enough. No side-to-side or up/down blade play.
The detent is a little weaker than I’d prefer, but it’s not bad. I can get my BM 940 to open with a firm shake too.
It’s really light and the scales will flex if you push in on ‘em. I’m not in love with that, but it’s a design issue, not a problem with fit & finish. Other lightweight knives will do that .
Overall, it’s a nice knife. I’d for sure call it a gentleman’s folder though.
knife open with lock bar engaged. Hold in hand.When you say no up or down play, how are you evaluating that? Just wondering if my standards are unreasonable or not.
I wouldn't mind having to do that work on a sub 100 dollars knife, but on a knife in the 250~350 range?Tactile dismissing blade play is total BS! Glad I didn't give them my money - I bought a micarta from a forumite here off the exchange & I guess I got relatively lucky, but I also had to put a little work into it.
When the package arrived I thought the action was sluggish. So I took out the pivot and blade and washers and got some 2000 grit sandpaper, and then very briefly polished the washers, the outside of the pivot, and the pivot hole in the blade. Then I noticed some tiny irregularities in the surface of the tang where it meets the lockbar, so I sparingly worked the tang against the sandpaper on a hard flat surface to even that out. Lubed and reassembled - had to negotiate with the very sensitive pivot screw. But I was able to get it where it will fly open and drop shut, but also lockup is fine. No vertical or horizontal wiggle. And I just checked the detent and it holds the blade in properly.
BUT I generally grab the blade in the middle to wiggle and check for blade play, and I just checked mine by wiggling at the tip and there IS a teensy vertical wiggle. Nothing I noticed before or would notice in use. Just like the dreaded bendy scales - I can bend mine if I try, but nothing that would affect use.
I really like the knife after 5 min of tuning it up (plus a sharpening) and it just feels like a more quality product than my Benchmades or other axis lock knives. In fact, if I didn't vastly prefer a lower blade tip my EDC search would have concluded with this knife. The clip works fine for me and the size is perfect. It really would benefit from a grippy backspacer though, to help actuating the lock . . . guess that's my next project!
I've had some crossbar locks with a tiny bit of vertical movement, but most of mine have locked up without any perceptible play. In a side-by-side comparison with my Hogue Deka and RSK, I can't get any movement out of the Hogues but there's audible clicking and perceptible movement with my Maverick. I always check every knife as firmly as I (safely) can for lock operation, so I'm probably catching more lock issues than most people do.Honestly, a tiny amount of blade play has always been a thing with this type of lock. I have a bunch of Axix lock knives, and none of them lock up as tight as a frame lock.
It would seem to me that if you get one of these and it actually has zero blade play at all, you should feel lucky.
That's just my take though.
I got the micarta first and was impressed, smooth action and solid lockup, no discernible blade play. The scales have a little too much flex though…
Most crossbar locks will do this, even coil spring designs like the anthem and MSI. The only ones I’ve owned that won’t needed to be broken in. I don’t consider it a defect, just the nature of the lock design.Both of my Tactile Maverick have ZERO blade play in any direction, up down left or right, with the blade anywhere between closed to fully open. There is no wiggle, pivot lash, or detent lash. And the detent feels good when flicking it open with the thumb.
However, I discovered that the detent from the bar lock is not strong enough to hold the blade closed when whipping the knife out really quickly, allowing me to flick open the blade open without touching the thumb studs or the bar lock.
Most? The < $100 Kizer Drop Bear that just arrived does not do this, and it's on bearings. I don't recall any of my Benchmade or Kunwu Pulsar and Manix 2 doing this.Most crossbar locks will do this, even coil spring designs like the anthem and MSI. The only ones I’ve owned that won’t needed to be broken in. I don’t consider it a defect, just the nature of the lock design.
