- Aug 2, 2010
Hey guys, It's been a long time since I've really had any interest in any "scandi" ground or bushcraft type blades, but lately I am really loving the "simple" elegance of the rhombic puukko, soo I want to make one!
. However, the geometry on them seems to be relatively complicated. (BTW, I am doing this one via stock removal btw, since my frrge area is a bit inaccessible at the moment and because I already have one profiled out lol ) Here is an example of a Rhombic "ground" Puukko. (I think they're normally reffered to as a "Tommi Puukko") They have a somewhat diamond cross section but with more "meat" left on the spine.
My question is, does anybody here know the process and order of grinding in the bevels on the edge side and the spine side? I've tried searching all over with no luck. I've also tried seaching for pictures of the spines on rhomibc puukko(s), as I've never owned or held one, and can't find any. The reason I was looking for spine pics is because I'm wondering how the spine side bevel terminates where it meets the tip, as well as how much thickness is left on the spine itself.
Also, I can tell it's not as simple as a straight up "scandi" grind that runs parallel to the edge, since the bevel is higher (thinner edge geometry) near the handle and the becomes lower (more stout edge geometry) towards and at the tip, which is another aspect I'm not sure about how to go about grinding.
As mentioned above, do any of you know how the spine side bevel terminates where it meets the tip area? If one is looking at it from the spine, is there a slight thickening right where the two bevels intersect, or does it flow into the tip area and remain the same thickness? I keep imagining going to grind in the top bevel, just to end up with a spine bevel that terminates at the tip, thus making something that resembles a double edged blade. Is the spine grind just as simple as grinding a spine bevel (leaving the spine thicker than a false edge or course) and then stopping about a half inch from the tip?
Grind spine first, or edge first, I do not know? I would deffinitely use a jig if I was doin a "pure" scandi, since I never do them and I'm not the best grinder
... However, since the geometry seems to change from heel to tip, I can't see that helping... BUT! This guy does use a "single angle holding" jig on his belt sander, starting @ 3:12 in the video posted below. And it looks like he uses it for both spine and edge bevels..
And FWIW, it's part 2 of a 2 part video.
I appreciate any and all help as always.
[video=youtube;CQfiIr8lyoA]https://www.youtube.com/watch?v=CQfiIr8lyoA[/video]
~Paul
My YT Channel Lsubslimed
~Paul
