How about you just send me the design and I will return heat treated blanks
But from my experience the best cheese knife was just a thin high tension wire stretched between two posts.
Kinda like a draw knife for wood but for cheese, I like it. We go through a ton of cheese in my house.Cheese shops ive been to often use longer knives with two handles (one on each side) to cut through larger pieces of cheese. But these are huge. Though .... when i have a bigger piece of cheese that i want to cut a hunk off of (either for cooking or to subdivide for storage) i find myself using one of my european knives (thicker blade, less acute edge angle), but use my other hand’s thumb on the knife tip as well as the handle side to “push down through the cheese block”. Yes, this does make me somewhat nervous for that thumb! Might be cool to design a home-size version of that larger two-handle cheese knife!
Exactly... though the handles are knd of weird - the close one is like a regular knife handle, but the far one is crosswise (at 90 degrees to the blade). Cant paste links on my ipad ... google the “boska dutch cheese knife” for an example. I guess you could execute that far handle as two part (one on either side) with a long pin through the middle?Kinda like a draw knife for wood but for cheese, I like it. We go through a ton of cheese in my house.
I like it ! Not hard to make it..............Exactly... though the handles are knd of weird - the close one is like a regular knife handle, but the far one is crosswise (at 90 degrees to the blade). Cant paste links on my ipad ... google the “boska dutch cheese knife” for an example. I guess you could execute that far handle as two part (one on either side) with a long pin through the middle?
I could make use of one also (smaller than the boska, which is made to go through huge rounds of cheese) - want to collaborate on a design, and you can cut out on your plasma cutter???
