For father's day I got a Gerber set which includes the Foreman flashlight, the Clutch minitool and the Resolve multitool.The flashlight is nice and currently my EDC, but that's not your question...
The Clutch:
It is a cute little tool, fit and finish is not bad, all tools snap nicely into place and will do their intended job (which I believe is to serve you in a pinch with simple light jobs), the knife blade was a bit unevenly ground near the tip but easily fixed by a couple of minutes on a hone, the mini screwdriver was kind of roundish on the tip but also fixed easily on the hone, I found the nail file not too comfortable to use and not coarse enough for shaping but workable for finishing or smoothing chips on my nails, the tweezers are small and not very strong but I could easily pull out hairs with them and I guess they should do fine with small splinters (the main pliers should do fine with large splinters), The main jaws feel well made. Not a bad tool to drop in you jeans pocket, I personally don't like much stuff on my keychain but you could put it in one.
The Resolve:
Seems very similar to the Suspension, with the same tools and steel handles, also similar to other Gerber tools including some with aluminum handles. I have mixed feelings about it, it feels large and heavy for what it has yet it seems to work and might be a good choice if you don't want to spend much in a better tool. In general it seems that they could have fitted more and larger tools in those large handles but that would have made the tool more expensive, so maybe it's kind of a compromise, better than a cheap knockoff yet not as expensive a top of the line multitool. One thing that I did not like was that the handles were widely separated even with the jaws fully closed, uncomfortable for my small hands, I removed the four little screws that hold the jaw stopper pieces in place, which caused them to slide out and stop at the raised section near the edge of the handles, now they fit me much better and seem strong enough. If I was to list multitools in order of preference the Resolve would be well below my Leathermans, Victorinox and other Gerbers (I have several of the 600 series) but those are all much more expensive.
Luis
