anyone know how hiking boots should fit?
Im very used to wearing lose sloppy sneakers all the time. when i wear a hiking boots it feels odd . Is there any down side to buying a hiking boot a little on the big side. Ill be wearing it for 70 percent around town, and 30 percent for actual hiking. I was thinking of going big, and when it comes time to hike just tighten down a little more. Also does tight or lose make a difference in keeping your feet warm in cold weather. Thanks for the help guys.
If you are planning on buying a decent pair I suggest going to a 'proper' store and getting one fitted. A decent pair of boots can last you well over a decade. Buy quality and cry only once (Shamelessly stolen from Maximus Otter :) )
Personal favs are Scarps for me but if you go to the Training > Wildeness & Survival section there is a thread there on good Hiking boots.
They should fit, period. Nothing is more miserable than a pair of ill-fitting shoes when you're miles from anywhere. Comfort while hiking (which is critical) should never be sacrificed for fashion and comfort while prancing about town.
Ever seen a blood-filled, half-dollar size, half-inch thick blister? :barf:
"Fit
The fit of the boot is the most important factor in considering
a purchase. Boots made outside the UK (especially Italy) are
often a narrower fit than boots made in the UK. Apparently British
people have wide feet so if you try on a non-British boot and it's
a bit of a squeeze, try and find a boot made in the UK. Regardless,
try on as many boots as you can in the price range you can afford
as no two boots will be the same anyway.
Size
Most people will require a boot that is larger than their normal
shoe size. A good rule of thumb is, while wearing a pair of socks
that you intend wearing with your boots, put your intended
purchase on your foot *without* lacing it up. Now push your foot
forward so that your toes touch the toe of the boot. If you can
comfortably fit a finger or thumb into the gap between your heel
and the heel of the boot then the boot is probably the right size.
The toe gap allows you to descend a slope while taking your body
weight on the instep of your foot rather than your toes. Move your
heel well into the heel cup of the boot and lace it up, making
sure that you're not lacing too tight. Walk around the shop to see
if the heel of your foot 'rises' within the boot despite being
laced up. A significantly rising heel will probably blister on even
the smallest walk and the boots are unlikely to ever be comfortable.
The rising is caused through a combination of the stiffening of the
sole of the boot and too large an instep gap in the boot cavity.
The foot flexes away from the stiffened sole into the instep gap
causing the heel to rise.
If you have already bought a boot that
permits too much movement consider fitting it with a padded footbed
to reduce the amount of space in the boot. Extra socks may also help
but the footbeds will reduce the amount of vertical space in the
boot without affecting the other dimensions. If a footbed
uncomfortably restricts the space available in the toe of the boot
then consider using heel pads.
Some insoles double as a shock absorbing medium. Specific brands include Sorbothane, Eagle Rock
and Superfeet. The author's own preference is for Sorbothane which
has been found to be both extremely comfortable and very long
lasting."
http://www.faqs.org/faqs/uk/walking/boots/
maximus otter
It's always a good idea to choose a hiking boot slightly on the large size. Your feet naturally swell on a day of hiking, effectively changing the size of your feet. Buying them slightly large will prevent a ton of discomfort.
It's always best to go boot shopping in the evening, after a day of working on your feet. Your feet will be naturally swollen to help get a perfect fit. If you can't do that, try wearing two pairs of socks when try on boots, simulating swollen feet.
