Anyone need adhesive transfer tape?
T Tjstampa I have not directly compared them. I have not used spray adhesive in years as I don't have the ventilation for it, and I just started using this particular transfer tape. I doubt you'll have failures with either one of them if applied correctly. It is harder to get a nice even coating with spray adhesive, especially if you're only coating one plate at a time and don't want to waste the majority of the spray shooting from a good distance. The 950 tape uses a thick layer of type-300 adhesive which is recommended for bonding porous surfaces like stone and wood, metal, and both high and low surface energy plastics.
I have more 1" wide 3M 950 acrylic adhesive transfer tape than I can use. If you're in the USA and need to mount Edge Pro format stones I can send you some.
I could most definitely use some, thank you! I'll PM you.
Edit - looks like I can't PM your account.
