- Dec 21, 2006
Can we talk about the difference between "apex stability" (AS) and "edge retention" (ER)? I think I can differentiate between the two, but would like to discuss this with you fellow sharpening knife knuts. Seems like there is a 3rd term associated with the other 2, but it escapes me at the moment. I'm backyard shade tree mechanic type....I really like learning new things/ideas/topics and not afraid to show my ignorance, as you can see from below:
Apex stability: The ability for the tip of the "triangle" formed by two intersecting planes to withstand chipping and/or rolling. Adhesive wear would play no role in "AS", but abrasive wear most definitely would.
Edge retention: Also the ability of the apex formed by the two intersecting planes to withstand chipping and/or rolling. Adhesive wear CAN play a role in degrading "ER", as well as abrasive wear. ???Most often refers to the overall working condition of the edge itself, not a specific location on the edge???
If a lateral load was placed upon an edge that was too great for it's strength, causing a chip to occur, then the AS suffered, at that spot, but ER overall (entire length of edge) may not have suffered, and is still serviceable. Someone may not notice the chip (AS failure), because the rest of the edge is still doing it's job, so even tho AS may not be as good as it could/should be, we would say the ER is OK?
2 blades identical in geometry, both having the best heat treat, 10V and 1095: I would expect 1095 to have better AS (generally speaking), but the 10V to have better overall ER.
That sound right to you? I REALLY appreciate any corrections, additions, and input. LOTS of very knowledgeable minds here.
