I'm wondering how to get an idea of limit to apex width depending on the micron rating of a stone, if possible.
I'm sure "it depends" on a lot of variables like type of stone, pressure used, angle?, maybe type of steel? and stuff like that. But let's say we're using a non friable type stone like a fine diamond plate rated around 25 micron.
Does depth of cut make more difference than size of grit?
Would the apex width be limited to the 25 micron rating or anywhere close?
Any ideas what the minimum would be?
EDIT:
It appears I'm way off base on width of apex guestament according to this post
https://www.bladeforums.com/threads/sharpness-chart.1535016/
and this link
http://knifegrinders.com.au/12Resources.htm
if the data is correct.
I often get to this point
EDIT:
and this link
straight off a fine diamond plate that's rated around 25 micron.- shave forearm against the skin against the grain /BESS 100 /0.2 micron
