- Oct 17, 2015
Yes on loctiteI see what you mean. Thanks for the heads up! Will definitely do a "feasibility study" before I rush it out to the tool bench. (anyone know, does Buck use threadlocker on those?)
I'd like to see that dark grey as well.Someone should try a dark grey dye and post some pics
Mike, The dyed micarta looks real nice
Hi Mike, Couple of questions, What type/Brand of Dye? Does the micarta soak the dye up? Will it transfer to hands?? I'm going to buy some grey dye and do a spot on the back side of the scales to try it outSome brown leather dye.
Two things.
If you have a Torx Plus kit, I have found that the 9ip fits the fastener better than the T10 bit. I’ve actually found this to be the case on a LOT of knives lately. I’m not sure if it’s because companies are switching to torx plus, or if it’s a tolerance thing.
Second, like with G10, I have had very good results dying Micarta with RIT dye. I did try Fiebing’s leather dye once, but I couldn’t get the handle to stop bleeding color.
That looks a lot better. I hated they did that on the 501 bom i almost didnt get it.Some brown leather dye.
Fiebings leather dye. Micarta seems to have absorbed the color. I did warm the micarta as well then buffed off. I used an applicator to apply. Quick wipe then again a couple times. This is alcohol based instead of oil based.Hi Mike, Couple of questions, What type/Brand of Dye? Does the micarta soak the dye up? Will it transfer to hands?? I'm going to buy some grey dye and do a spot on the back side of the scales to try it out
The back side of the scales is not sanded. Results might be different unless you sand the gloss off.Two things.
Absolutely. There are a few videos on YouTube that show the use of dye or tint added to the resin. I may just attempt this myself with some dark denim.Never tried dyeing micarta, i've made some beautiful scales with it, but it's always been the case for me that the fiberglass resin bleaches a lot of color out of the material, wonder if you can add dye to the resin mix to keep a deeper color?
Not a Buck, sorry, but here's an example, I used denim for the micarta, it was older black denim that had faded somewhat to a nice charcoal gray color, but after the resin bleached it, this is how it turned out, not bad looking at all but not the deeper color I wanted:
Mine arrived today. The finish on the handle tang was not on par with my other three 104s. It has noticeable grind marks that did not get polished out. On the one hand the buffing compound is highlighting it in the photos, on the other hand they are more noticeable with the naked eye. Of course, this is a camping knife, so not a big deal.
The edge grind is on par with the others, but is the roughest of the four. The grip on this one is in between the SK handle (as expected) and the the other micarta handle. I was wiping the blade off with mineral oil and got some on the handle. Now I think I might have to coat the whole handle with mineral oil.
I need to get my DSLR camera out and take some pics after I figure out the lanyard....
Agreed, especially after paying the premium for a bom. While easily fixed, it's not worth sending back, but still shouldn't have been that way.Camping knife or not, that's just plain atrocious...it's workmanship you'd expect to see on a cheaply made knife from China, and not Buck.
I think it is more because the dye in the denim is not all the way through. It sure wouldn't hurt to use a dark gray dye on it if that's the color you wanted. Maybe next time pre dye the denim pieces to the color you want.Never tried dyeing micarta, i've made some beautiful scales with it, but it's always been the case for me that the fiberglass resin bleaches a lot of color out of the material, wonder if you can add dye to the resin mix to keep a deeper color?
Well crap. Not enough pressure around the handle to secure the knife in the sheath. Slip sheath similar to SK's version most likely will work best.View attachment 1552068 View attachment 1552069 View attachment 1552070
