- Nov 5, 2016
I finally got a chance to try out my Graham Forge from Atlas Knife Company. This is my first gas forge, and I'm still very new to forging in general (only started this summer). My say so doesn't hold much clout, but I'll give it anyway and say I like it a lot. My first forge was a Whitlox Mini wood fired forge. It worked well, and I held onto it for odd shaped things, but tending the fire and dealing with heat variance was always tricky for me. I'm pretty hooked on this gas forge world now where it turns on quick and runs steady and smooth with no effort on my part. The time in the heat to get back to temp is also a lot less, so I spent more time hammering than I usually get to! My right arm will need to learn the new pace...
While I really don't have any other gas forge experience to compare to, my take is this Graham Forge from Atlas is a great forge. The thing is solid, but I also had no issue carrying it with the attached handle. It was really easy to get setup, and it runs very quiet. I'd recommend it to any other newbie looking for their first gas forge. Stacy did a much more in depth review than I can muster (that thread is how I found this forge and a big part of why I bought it). I did take some video though in case others want to see it in action. For context, this is in Vermont where it is 32 degrees outside and was a little windy today (couldn't keep the stick lighter lit). There was talk in the thread from Stacy about how low you can make it go, so in this video I'm running it just above where it would start to sputter. It can go MUCH hotter than this. I cranked it up after to actually forge that spike into a tomahawk as a gift for a friend. I haven't cranked it to full yet. Some day I'll crank it all the way and try my first forge weld (well I tried once with the wood forge and failed miserably).
[video=youtube;KjOmsBaXnVk]https://www.youtube.com/watch?v=KjOmsBaXnVk[/video]
