The Atoma 140 is OK for bevel setting. I wouldn't apex with that stone. The 400, sure, but not the 140. However, MaggotBrain is giving great advice. When lots of pressure is required, and bevel setting can demand some pressure....diamond stones are not the best choice. You'll likely damage diamond stones when using high pressure. They're meant to allow the diamonds to do the work. Cheapo SiC or Crystolons.....check!
I used to think the same thing....get a low grit diamond plate to do serious geometry setting and corrections. Not really the best choice for that. I can say the Sigma Power 120 is an awesome stone for that chore, but that stone requires some care during use. Loads pretty easy. Bought a Naniwa Eco 120, using it with oil. Fast cutter, but dishes very easily.
I find myself going to used sanding belts at 80 grit to do many bevel sets. Cut 'em, spread it out on flat surface, lock it in place with clamps, and go to town! 4"x36" of 80 grit abrasive....makes bevel setting trivial.
