Found this for sale in Northern Arizona.... I thought (but not sure) it
had enough good steel remaining under the rust that warranted an
attempt at resuscitation. As most here are aware these double bits
are frequently subject to aggressive grinding for use on the fire lines...
this one appears to have reasonable bit edges left and temper lines while
not deep are present and still indicate some life left in this head. The
seller indicated this was located on the Fort Apache Indian Reservation
in the White Mountains.
So, a work in progress... next will wire brush the surfaces and eye. Then
mill file the bit edges and re-haft. This should make a nice companion for
my True Temper F.S.S. Pulaski that lives in the truck. I know, nothing rare
or collectible here... but, I enjoy the process. So far I'm out $9.00.
(adjacent to F.S.S. this one has a "B7" imprint). I suspect not especially
"vintage" ... based on what I've read here I'm thinking 60's-70's. I haven't
weighed the head but I believe it will weigh in between 3-4 lbs..
Charles
https://imgur.com/a/NJIX4CZ
Charles
