- Oct 1, 2002
Are any commonly available paste-like compounds ok for a leather strop?
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
"Mothers Mag & Aluminum Wheel Polish" works VERY well as a stropping compound, as do all of the various grits of lapping compound, which get very, very fine and produce a great polished edge.
But... you do NOT need to ruin good leather by putting compound on it. You'll be better served putting the compound on MDF board or a smooth flat hardwood plank. A lot of woodcarvers use compound on a cheap paint stirring stick! Use the leather bare. That's what leather is for. Unless you are trying to convex the micro-bevel, using leather with compound doesn't result in a better edge than glass with compound.
Stitchawl
Good to know. So mother's mag polish on a paint stick will work? That's great. I have a piece of decent leather glued to a 2x2 as a leather strop, and I was gonna put compound on it, but I think I might leave it bare and try the wood/compound combo if that'll work.
Chromium Oxide polishing compound (the green stuff) can be found pretty cheap, probably cheaper than a rubbing compound.
Some people argue you don't need compound, I like it to improve polishing speed on the edge.
Auto compounds are not even as fine as a spyderco UF ceramic in most cases. The common Red rubbing compound is around 600-800 grit, most polish compounds are about 1500-2500 grit. .
