In this case I would heat it up and put it in a vice between two hardwood blocks.yeah about this, my kelly hand made has this problem. the twist is it's a kelly hand made and the marking is in the way
Like Squre_peg recommended practice on a head you don’t care about. If you feel good about the result then go for it. Could you explain what you mean by steam bending?so about that kelly handmade, i dont know if i want to steam bend it the 10 or so degrees it needs or fix the eye. which do you guys think?
steam the lower 8 or so inches, clamp it up and twist the handle slightly so it produces the same effect as straightening the eyeLike Squre_peg recommended practice on a head you don’t care about. If you feel good about the result then go for it. Could you explain what you mean by steam bending?
At this point I had a pretty good handle blank. I set my axe on the blank, aligned the bit to the haft and traced the eye on the end of the haft. Some of you may have run across axes where the eye didn't align perfectly with the bit. By tracing the eye with the bit aligned to the haft I avoid trouble here.
