David Martin
Moderator
- Apr 7, 2008
I'm wondering, to what grit do you experts sharpen your axe to? With splitting or limbing, is there a difference in performance? Thanks, DM
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
The less friction on the edge the better it will cut, so in theory a edge sharpened to 6000 grit will cut better than a 400 grit. I think.![]()
True Grit
for me
oh well i thought that was pretty funny.
i sharpen the edge til it gets sharp, simple. if there are any file marks sand paper scratches or other ugly looking marks i sand them off or away til i'm statisfied.
an axe is a cutting tool. its gonna get rough treatment in these Oak/Hickory forests here in Midzoory so she needs to be sharp but don't look for her to shine for long. bangin' her face into hardwood will mean a touch up now and then to keep her shinin'
buzz
As well, the process of honing and then stropping will reharden the edge. This takes a lot of stropping, and some will say it's bunk, but the top knife sharpeners and axe sharpeners take the time to do it.
It's false attribution. What you are seeing/experiencing is not the result of hardening at the edge. Just because they do one thing and get a particular result does not mean that it is due to the reasons they state. Heat would not harden steel, and it is not work hardening from displacement of the crystal structure. There is not a mechanism at work in that method that is able to induce an increase in hardness. The closest thing there is would be if any burr or wire edge is present it will work harden and break off due to being folded back and forth a bunch of times, but that isn't going to produce an increase in performance vs simply sharpening to a fine apex without developing a wire edge in the first place.
.....sharpened my 'True Temper--Kelley Perfect' double bit axe up to a true hard Arkansas.
