- Feb 1, 2012
I think those small hatchets look better on curved hafts. But the straight haft might be more useful and practical.
That looks great Cteve!
Thanks! The marks are from 2 different gouges a 20mm for the sides and a 35mm to do the bottom (makes it more flat) the wood is very green, I cut the tree down 2 weeks ago. The only tools used to carve was the axe a couple gouges and knife. As well as alot of timeThat looks great Cteve!
A few questions, those tool marks that are visible are they from a spoon knife or gouge or something similar, and is that wood green or dry?
Time well spent I would say! One other question, is there a special way you dry it so it doesn’t crack?Thanks! The marks are from 2 different gouges a 20mm for the sides and a 35mm to do the bottom (makes it more flat) the wood is very green, I cut the tree down 2 weeks ago. The only tools used to carve was the axe a couple gouges and knife. As well as alot of time
There sure is, I have been using two different ways, the first one is to keep the wood chips from carving the bowl and place them into a paper bag and then i cover up the bag with some old furs, this is to act sort of like a kiln, you want it to dry slow as possible. I have had a lot of success with this way and a few that didn't work.Time well spent I would say! One other question, is there a special way you dry it so it doesn’t crack?
Thanks for sharing, I’d like to give it a try myself.There sure is, I have been using two different ways, the first one is to keep the wood chips from carving the bowl and place them into a paper bag and then i cover up the bag with some old furs, this is to act sort of like a kiln, you want it to dry slow as possible. I have had a lot of success with this way and a few that didn't work.
The second way is called "water displacement" this is where in theory, you replace the water in the wood with oil (i use 100% pure Tung oil) this way seems to get better results but there is still a chance of cracks developing, however i noticed many of the cracks close up as it fully dries/cures.
I spent too much on a Kelly Perfect Jersey on the bay. It was garishly polished, and I wasn't about to hang it like that. I'm not one for the grey on grey of a straight vinegar soak, so I finessed a strange patina with hot vinegar, Gunzilla CLP, and improvised technique. Looks like a movie prop, but I dig it. I had done up the edge before, and used nail polish as a resist on the edge and back a bit. Wanted something like the glowing edge the swedes have made so popular. I like it, but I think it'll be a love it or hate it thing.
https://www.dropbox.com/s/jawjhe17nwyb4f0/20181009_013834.jpg?dl=0
I'll have to figure out how to properly post images here. For whatever reason an image url from a Dropbox generated url (as above) doesn't work so far as I can tell.
ETA: I forgot to mention, the CLP rubbed in with the hot vinegar as red iron oxide was forming for some reason resulted in that bronze hue.
The vinegar soak is SUCH an easy way to remove rust though. I like it better than almost anything else I have tried, including Navel Jelly. I found Cleaning Vinegar has a 6% concentration, verses general vinegar at 5%. Lowes has a jug for less than $2. 1% More doesn't sound like much, but it is 20% more of the "Good Stuff" in the solution.
The gray on gray pattern goes away if you polish it with a buffing wheel, SOS pad or Scotch Bright. Norton makes an awesome pad that might be of interest to folks on this site.
They are called the Norton Bear Tex Hand Pads. I use the maroon colored one for axe heads. They are like Scotch Bright pads on steroids. Not recommended for stainless. The pads seem to last forever and the don't rust or splinter like steel wool. I even use them like a strop for heavy duty tools like my machetes. If they get dusty, you can rinse them out since they don't rust.
Amazon has them 20 in a box. The site below, which I randomly found, has them in sets of 5 per box. The pads last a really long time. I'm still using the first two i started with about 9 months ago. If you have any round metal that you can spin in a drill chuck, they also polish round items like nobody's business. I even cleaned up some stainless bolts that way. Note: I think they might leave marks on flat, sooth stainless.
https://www.theruststore.com/Norton...EMmWr3ea_5Yp2snpDuIiock5Yd79OgrhoCgZMQAvD_BwE
Yeah! I was not an axe guy but I am hooked now. His attention to details is superb.Liam does such fine work.
