Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
When you're sharpening on a stone, when should you sharpen back and forth, without lifting the blade from the stone? Is it only in the lower grits?
There are several ways of getting the job done, the important thing is getting it done. Knowing and understanding what's going on and applying that knowledge to your particular technique will help. For me, I have tried making circular motions it works but now I tend to do back and forth motions for the initial metal removal and than I switch techniques when I am finishing up the blade on that particular stone.
When I first started out with freehand I used circular techniques. I found, over time, that this tended to create a wavy looking bevel as I slightly changed the angle while sharpening along the length of the blade. Instead, I now use diagonal back and forth strokes.
Now that my angle control is better and much more consistent, I'm curious to see what would happen if I went back to circular strokes again.
I do it on all stones. Depending on the stone type I will finish with sweeping forward strokes or a few edge trailing passes to remove the burr. Scrubbing the edge on the stone is simply more efficient than making one stroke at a time.
Fore and aft until a burr is formed, leading to remove it, and then finish with a leading or trailing edge depending on the stone/abrasive surface. My hands are already going that way, might as well have them do some work unless there's a good reason not to. It doubles (or nearly so) the amount of steel you can remove per unit of time.
You might be surprised, and even impressed. I've always been amazed at how my hands, seemingly by themselves, have 'learned' to do things by repetition, in spite of what I assumed I hadn't yet learned. It's a thrilling surprise to suddenly discover the skills are 'just there', after having struggled to learn them for so long. All of a sudden, techniques and tools that I'd previously written off because they 'didn't work' just mysteriously start working, sometimes excellently so.
David
Well I don't know but from what I heard from the Lansky system , the most efficient way to sharpen is with a sweeping motion not sawing.
Jump to 3:48
[video=youtube_share;n97hZbHtY2I]http://youtu.be/n97hZbHtY2I?t=3m48s[/video]
