Bahco/Sandvik 19 inch Rucksack Axe Review
In this review I would like to take a look at two sightly different axes. A while back I came across a small axe with the name Sandvik on it. I bought it for about $20. Recently, I noticed that a very similar axe is being sold under the Bahco name. After some reading, it became clear that Bahco had purchased Sadvik. I bought one of the Bahco axes, so I can see if there have been any modifications made from the Sandvik model. In this review I will switch between the two axes.
Specifications:Manufacturer: Bahco/SNA Europe
Axe Head Weight: 1 3/4 lb
Axe Length: 19 3/4 inches
Axe Head Material: Unknown Swedish steel
Handle Material: Hickory
Cost: $40 for the Bahco version
What you see in the above in the first picture is the Sandvik Axe, and in the second picture is the Bahco version.
The two axes are nearly identical. Aside from color, there are only two differences, both in the head. The first difference is that the poll of the Bahco version has been made heavier. It still doesn’t provide ideal balance, but it is an improvement over the Sadndvik version, which had a very small poll. The second change is of questionable value. For some reason, Bahco changed the attachment method, ans is now using a plastic wedge to attach the head. Even more bizarre is the fact that the wedge has some sort of attachment loop on it. During testing the head stayed on securely, but this choice is hard to explain.
Otherwise, both axes are the same size, and are comparable to the Gransfors Bruks Small Forest Axe. Here you can see the axes next to each other.
The handle grain is hard to see because of the paint on the handle, but it is good on both axes. The handle is the same length as that of the Small Forest Axe, but it is noticeably thicker, too thick for my liking.
The head of the Bahco/Snadvik axe is a quarter of a pound heavier than that of the Gransfors Bruks Small Forest Axe. It also has a very strange shape. It almost appears to have been designed as a splitting axe. While the bit is fairly thin, the head quickly widens in the cheeks, making it appear almost triangular. It reminds me of an old Stiletto head of similar size that I have.
While it would be possible to do some work with a file on the bit of the axe, how much can be done is limited by the abruptly widening cheeks, which get in the way. If you wish to re-profile the axe, you may have to grind down the cheeks.
Because of this “splitting” design, the Bahco/Sandvik axe falls behind the Small Forest Axe when it comes to chopping. Here I had sharpened the axe, but had made no effort to re-profile the bit. I am sure that with some work, the axe can at least match the performance of the Small Forest Axe. I don’t know how easy that would be to do considering that the cheeks expand so rapidly from the bit. In splitting of course, the added weight of the head, combined with the wide head design, the Bahco/Sandvik axe shines.
The balance of the Sandvik axe was terrible, as the poll was very small.
I am very glad that the Bahco version has an expanded poll. It still doesn’t balance out the axe completely, because of the short handle (I like to see 1 3/4 lb heads on a 25 inch handle rathern than a 20 inch one), but it is a huge improvement over the Sandvik version.
I am not really sure how to judge the Bahco axe. It is a very peculiar design. In some respects it shows a lot of promise. The bit is fairly thin, and the overall size of the axe makes it very portable. The price is also very reasonable. On the other hand, the wide cheeks make it more suited for splitting than chopping. The attachment method that is used int eh Bahco version is just bizarre. I don’t know what to say about it. It held together during testing, but just looks like something you can pull out (I tried-I couldn’t pull it out). As it is, it can not outperform the Gransfors Bruks Small Forest Axe. With some work however, the potential is there.
Bahco also makes different size axe including a version with a 26 inch handle and a 2 1/4 lb head.
Ross
http://woodtrekker.blogspot.com
thanks for the review! kinda had my eye on one of those bahco's, until the review.
plastic wedge, wtf?
Sandvik is a large swedish conglomerate. They used to sell hand tools under their name.
Now the hand tools are called Bahco for some reason (sold away? rebranded?) using the same "fish logo" (at least in the beginning). Anyway as you pointed the old Sandvik hand tools and now Bahco are the same company.
Pretty big hand tool company aimed at professional. Production has probably been sub contracted to various makers during the year. Have seen old Sandviks stamped sweden, and have a Bahco stamped Germany.
That's the best I can get out of the average hardware store around here.
I'd call this professional/decent hardware shop grade. Since nowadays professionals lumberjacks use mostly chainsaws for cutting and even limbing it means those aren't so good.
These are meant mostly for splitting and rough tasks. Edges are pretty obtuse because these are considered expendable tools (I've seen people chop over rocks) and axes hardly get resharpened. They don't even come with any edge protection (sometimes a little piece of rubberlike material). Those things are a league above "no name"/china axes:
* at least heat treatment is generally Ok: you won't -generally- have pieces of the edge stuck in the log when hitting a knot)
* head is better fitted (won't get loose after a few blows)
* handle is generally ok although grain is generally random.
but several leagues below stuff like GB/Wetterlings/Hults... which nowadays are mostly used by "hobbyist" anyway.
About the hook on top of the wedge: it's just for seller's convenience to hang in hardware shop, really. No practical use. You should remove it. Wedge is glass fiber reinforced plastic. Nothing great but does the shop.
Curious if the Bahco actually has a stamp in the head? I like the price for that axe if the head truly is Swedish steel. I don't mind rehandling it and using it as a small camping splitting axe, which your review would suggest it might make a good one. My concern is that I know some Bahco stuff is now made in (ugh) China ! The last thing I want on earth is a Chinese axe head that might as well be made from recycled Hot Wheels. (double ugh!) - so curious, does the head actually have indication of being made in Sweden?
