- Dec 27, 2010
Well, I finally got in my Baltimore Knife and Sword Tactical Gladius. Matt had contacted me nearly a year ago when I mentioned I wished I could have something like the Gage, but at a less expensive price point. I ended up paying 420 USD shipped for this, which is much less expensive than the Gage, for sure. They could have made up a leather sheath, but I'd prefer kydex for this, and I can make my own leather sheath if I want. I really like this sword, and will certainly bring it by the BKS booth at the Colorado Renaissance Festival, just in case I get to meet the master behind it. Here's some of the base stats:
Overall Length = 29"
Blade Length = 22"
Point of balance = 3.25" from the cross guard
Fuller Length 17.5"
I took a length comparison with the 18" short gladius I made myself a while back too:
Amusingly enough, they weigh almost the same amount, since the stock appears to be between 1/8" and 3/16". It's certainly not as beefy as the Gage, with the 1/4" stock on that sword. But, it's light and fast, which is all to the good for a short sword like this.
BKS goodness:
Overall, I definitely like this sword, and it's well done. There's a few flaws here and there that indicate that this is a handmade piece, not just something ground out on the machine. For instance, the grinds on the tip aren't perfectly even:
Overall, the finish on this is really nice. What scratch pattern there is, is vertical, which really looks nice. The plunge lines aren't perfectly even, but have a pretty nice swept appearance. Really, the only flaws I could find in the finish are around the guard, where there are a few grind marks and what appears to be epoxy. If you can see it, good for you. They're very minor flaws.
On a piece this big, that's good work. Maybe not $1000 custom good, but it's those little things that tell you this is a hand-made creation. It has that smell I associate with an oiled sword also, which is nice. I'm pretty sure this is the first piece of this type that Matt's made, and I sure hope that more people go for one like this, because it's a really cool sword.
On first handling, there's really only 1 thing that I don't like about this sword, and that's the handle. Three issues here. First, while the pommel is somewhat flared, it's largely just straight. Adding in a more significant pommel would have lowered the point of balance, which would probably be good, although it's pretty darn close to perfect, and also helps the wielder keep a grip on the sword. Handle shape is pretty much the most important thing with regards to retaining the blade, and this is just a little too basic to get the job done ideally. Matt was originally planning on doing a drawing for me to approve, but somehow that didn't really happen, and he had the whole sword made up. That's really one of the few things I'd change about this blade though, because it just feels so NICE. Sharpening job was good; not shaving sharp or anything, but about what I'd call battle sharp. You don't really want a combat or heavy use blade to be much sharper than this one.
There are a couple other things that bother me about the handle. First, it's a 2 pin design, which isn't the most durable. But the pins are nicely finished, and it's certainly quite secure. I may end up rehandling it anyways, so I'm not exactly worried here. The other thing, and this is my least favorite part about this sword, is that the handle is very blocky, and the scales aren't rounded at all by the guard. It's quite uncomfortable, in fact.
I'm a stickler for comfortable handles, but there's a lot out there that just aren't. I got a carved HI katana, which had probably the most uncomfortable handle I've ever felt:
Also, I got a Badger Blades waki last year, and the guard on it was too small for the sharp edges it had on it, and that cut into my knuckles. Fortunately, all of those were easy fixes, and I'm pretty okay at fixing issues like that. Here's the HI katana now:
I'm going to round out the scales on this and see what I can do to make them a bit more comfortable. Failing that, I'll just boil them off and rehandle it, probably in G10 or micarta.
Now, I don't want to give the impression that I don't like this sword, or that I think Matt did a bad job, especially given how little communication we had. I definitely love this sword. It's very fine work, and I'm proud to own it. I did want to present a balanced perspective, so I spent a bit of time on the really minor negative things. So let's talk about what I love about this sword.
For starters, it's just so light and whippy that I can barely believe it. It's a pretty wide blade, being a gladius-type weapon, after all. And it's a 22" blade. But with the perfectly done fuller on each side, it's nice and light and fast, which is really important to the way I fight. Now, this one's a sharp. It's battle-ready. So I'm not gonna be sparring with it, like I could with most of Matt's blades, which are designed for stage combat. But by the same token, I know that this one should be a nice durable blade.
There's a few little details I haven't gotten from Matt yet. I don't know what kind of steel it is, although I suspect it's 5160, since it's pretty springy. Maybe he'll answer that one for me. I also don't know what kind of wood got used on the slabs. It's got a lot of character to it, and has nice grain. I'm looking forward to working with it a bit when I refine the handle shape.
I also like the tip profile. It's a bit thinner and pointier than the Gage, but not by a whole lot, and looks like it will have good penetration (important for a gladius), but still looks to have enough behind the tip that I'm not too worried about it breaking. And, after experimenting with finishes myself, I'm very impressed with how clean this one looks. I'm very excited to see what it can do. Thanks very much for a fine sword from Baltimore Knife and Sword!
Blade Length = 22"
Fuller Length 17.5"
BKS goodness:
