Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I'm waiting for some info and data from the manufacturer, but there is an interesting upgrade package at Woodcraft for the Rikon 14" series of bandsaws. It is a digital DVR control and motor upgrade that makes your bandsaw operate like a DRV drill press does. It has torque control, speed control, and is pre-programmed with the cutting parameters for everything from scroll sawing thin plastic, to titanium, to carbon and stainless steels, to re-sawing 12" logs. It also has instant braking.
https://www.woodcraft.com/products/smart-dvr-control-and-motor-upgrade-rikon
It regulates the speed depending on the cutting resistance, and increases/decreases the torque as needed for the material being cut ... automatically. It costs $629.99.
It will soon be available on new Rikon saws for $600 over the regular saw price..
It will allow cutting speeds and power control from 45SFM to 4400SFM.
All you need to do for installing the kit is switch the motor out and attach the control panel to the upright arm. Everything, including the motor, is in the kit.
In use, you select the material and other parameters, move the drive belt to high or low ( these bandsaws have two speed ranges), change the bandsaw blade to the type you need, and hit RUN.
I will post more when I get some info back from the tech support guys.
