band saw vs. scroll saw
Jason Fry
I found some older tools today at a price I might can afford. One was a Craftsman bench top wood cutting band saw. It was labeled 10", but had no blade dimensions or HP rating obvious. The other was a bit older Craftsman 16" scroll saw. It appeared to be single speed, 1/5 HP, but it came with a stand. For knife making applications, which would be the most useful?
I've never had a need for a scroll saw. If I had one or had access to one maybe I'd use it, but I think the bandsaw will get more use.
Can you profile handle material with a band saw the way you can with a scroll saw? My dad's got a scroll saw that I've used before, but I haven't used a band saw.
I don't know about knife making applications specifically, but in general, a band saw is good for more generalized cutting where fine detail is not necessarily required. A scroll saw is much better at the very fine detail type of work.
That said, a scroll saw is an investment that requires a fair amount of $$$. If you buy something cheap, that cheapness will probably be obvious in whatever you are making. It's not like a drill press where you can probably get by with something for $100-200. IMO, no scroll saw is better that a cheap piece of garbage.
I bought myself one of the Craftsman scroll saws and tried it out for about 5 minutes before deciding to return it the same day. It didn't seem to want to cut even 1/4" hardwood. I thought about getting a small bandsaw and trying that, but most I don't think have enough power to cut through thick resinous hardwoods. I set up a Sawzall under my table with the blade protruding up through a slot in it. It has a whole heck of a lot of power and I can cut through 2" thick cocobolo if I wanted too. Doesn't take up space in my shop either. It's a bit crude, I know, but it works!:D I could be wrong about the small bandsaw though, it might be just fine.
A scroll saw (very good quality like a Hegner or RBI) will take forever to cut a steel blade profile. A cheap one (like less than $1,000.00) will be terrible. A steel cutting (80 FPM) will work great. Scroll saws are great for inlay, fretwork, fine fine detail pierce work. Great for woodworking as an example.
Good luck,
Balin
I would suggest a portaband, stick it in a vise make a larger table for one it comes with and wala....you have a verticle metal and wood bandsaw. btw, depress the trigger then drill a small hole to put a pin in it so when it is plugged up later the pin keeps it on and you have two hands on the material.
I use corian for the table. hope that helps,,,,,,and you can get bye with a harbor freight one.
