Bark River- who’s fault?
I used to lurk on here a lot. Haven’t been on here in a while, and never really had anything to post about until now.
I have a BRK Edwin Forrest Bowie. Long story short I cut a 1-2 inch limb and the blade behind the edge bent in three spots. It most likely bent because I didn’t pull it exactly straight out of the limb; however, I didn’t just grab the handle and torque it sideways either. It was just a slight wiggle to loosen the blade from the limb. Compared to their other knives in A2 this seems uncharacteristic. This is beyond edge damage; this is actual blade deformation behind the edge. In Bark Rivers description of this knife it states “whether you use it or collect it— this is an all business knife.” I don’t think what I did would be considered abuse, but I would like to hear your opinions. Not entirely sure how to add pictures so I’ll include a link to a video of it.
Did you reach out to them? It’s been three days since I emailed them and no response. Do they think people won’t use the knives just because they’re on their “historical line.” I’ve heard some horror stories with them.
I sent it back to them and I got back a much smaller knife. You know, they just took it to a grinder and ground out the chips.
That knife, and the rest of my once extensive BRK collection are other people's problems now.
If they ever respond to me I figure that’s what they’ll do. Send me back a toothpick. Not to mention the grind is horrendous just curves off to one side. I sent the first one back too because of the grind but settled on this one even though it’s no better.
I had similar edge problems with an Aurora and another BR model that slips my mind, but yeah, after the Bowie experience I had to ask myself why I was such a glutton for punishment.
Lots of better choices out there for the same or less money.
Here we go again....
Bark River has a proven and documented history of mis-representing their blade steel. For all we know, your knife is made of un-heat treated Jello.
There is lots of information about Mike Stewart and his immoral business practices and ethics, if you search for it.
I should’ve listened the first time I read those types of things a while back. If it even is A2 then I believe there is a HT issue.
If the blade warps, then it wasn't designed for chopping.
Specifications:
Knife TypeFixed Blade Blade StyleStraight Back
BrandBark River Blade EdgePlain
Product NameEdwin Forrest Bowie Blade GrindFlat
Model #08-315M-NC Blade FinishSatin
Overall Length17.00" Handle MaterialCanvas Micarta
Blade Length12.5" Handle ColorNatural
Handle Length4.75" Sheath MaterialLeather
Cutting Edge12.00" Sheath ColorBrown
Blade Thickness0.18" Weight18.6 oz
Blade MaterialA-2 Tool Steel OriginUSA
Blade Hardness60 HRC DesignerBark River
The blade length, thickness, hardness, and grind tell me it's a delicate blade. I don't think it's good for a lot of chopping work.
I personally don’t mind BRK, had 1909 Michigan Bowie that looked decent. Never used it however. Definitely wouldn’t trust it compared to my Busses and Beckers. I also believe they probably won’t stand behind their product like Busse and Becker.
Specifications:
Knife TypeFixed BladeBlade StyleStraight Back
BrandBark RiverBlade EdgePlain
Product NameEdwin Forrest BowieBlade GrindFlat
Model #08-315M-NCBlade FinishSatin
Overall Length17.00"Handle MaterialCanvas Micarta
Blade Length12.5"Handle ColorNatural
Handle Length4.75"Sheath MaterialLeather
Cutting Edge12.00"Sheath ColorBrown
Blade Thickness0.18"Weight18.6 oz
Blade MaterialA-2 Tool SteelOriginUSA
Blade Hardness60 HRCDesignerBark River
Possibly, I didn’t do a whole lot of chopping work. This was the second time I used it so far.
Specifications:
A true 60 HRC in A2 shouldn't bend or roll. If anything, I would expect chipping. There is something not right about the HT of this knife, by the sounds of things.
Specifications:
Those specs are theoretically “tougher” than many knives I’ve put through WAY harder use than what OP said he’s done with his.
Imo there’s no way this is anything but a manufacturer’s error / faulty knife.
I want to like Bark River. I like their designs, steel choices, and they seem all above board and good people to do business with but there are too many stories. Numerous problems notwithstanding, the way they've appeared to handle them has surely turned me off completely. They're not even a consideration for me. Too bad.
100% on Bark River. They have an extensive history of these sort of problems. Good luck getting a resolution, since they have a horrible reputation with dealing with these problems as well.
Where there's smoke, there's fire. And Bark River is an inferno.
