Any chance the Manticore material can be put onto a emery cloth type paper? I'd really like to have a very abrasive but flexible paper for reprofiling convex edges.
Could you package you stones in a tri hone
You mean one of the Norton-style rotating systems? That's not something we're able to offer at this time, though in the future we could theoretically make replacement stones that fit the system.
would it be economically viable to make the two stones separately and glue them toe each other or perhaps some sort of center material in order to avoid this expansion issue or would this not be durable enough/have other problems?Binder shrinks during firing but the grains don't, which makes for a difference in shrink rate between the sides. If the jump is too big the stones will pull themselves apart when fired, which was an issue we ran into when developing the Arctic Fox dual grit pucks originally, and why we can't make them in bench stone sizes with a dual grit.
I use water with my personal one. It retains water decently for something as coarse as it is, and I give it a quick rinse periodically as swarf builds up on the stone, and that's enough to keep it wet once it's been saturated. It'll cut a lot faster than the American Mutt, but it definitely leaves a more visually coarse finish. It's also not as dependent on high pressure to shed grit as the American Mutt is, but it does still hold together well even when you bear down on it hard.
What's your stone/grit progression when you start with a Manticore?
